i manage to set 3 diff 18ds20 sensors on my locak blynk + turn on and off a relay on my GP13
the only matter now that i want to create a thermostat from one of the temp that will open and close my relay so the water
heater in the fish tank will turn on and off.
does anybody have an idea how to implement a thermostat ? ive looked everywhere and found some jobs but without any code or guide.
here is the code ,
thank you very much
char auth[] = "certificate auth for blynk";
char ssid[] = "wifi ssid";
char pass[] = "wifi password";
/* TIMER */
/* DS18B20 Temperature Sensor */
#include <OneWire.h>
#include<DallasTemperature.h>
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board
DallasTemperature DS18B20(&oneWire);
float temp;
DS18B20.begin();
timer.setInterval(1000L, getSendData);
* Send Sensor data to Blynk
void getSendData()
DS18B20.requestTemperatures();
temp = DS18B20.getTempCByIndex(0);
Serial.println(temp);
Blynk.virtualWrite(10, temp); //virtual pin V10
temp = DS18B20.getTempCByIndex(1);
Blynk.virtualWrite(11, temp); //virtual pin V11
temp = DS18B20.getTempCByIndex(2);
Blynk.virtualWrite(12, temp); //virtual pin V12
You’ll need to modify this a little to suit your needs,as the “temp” used to activate the relay has not been assigned to it. Once those details are added, this code should work fine.
/* TIMER */
float temp;
int relayPin = 13;
int desiredTemp = 0;// set this to your desired temp
int tempDiff = 1;// this variable provides a small +/- temp differential that will prevent constant relay switching.
void getSendData()
void Heater() {
if (temp <= desiredTemp - tempDiff ); {
digitalWrite(relayPin, HIGH);
if (temp >= desiredTemp );
digitalWrite(relayPin, LOW);
DS18B20.begin();
pinMode(relayPin, OUTPUT); // set your GPIO pin to OUTPUT
digitalWrite(relayPin, LOW); // set the pin LOW or HIGH for OFF, depending on your relay's wiring.
timer.setInterval(10000L, Heater);
