I Was trying to use spark interval library to Push data to blynk from Particle photon to avoid flood error .
But both have some conflict as spark interval library functions works only when blynk.run(), is disabled as verified from led blinks .
is there a example for pushing data,send email ,send notification to blynk from particle photon .
Is there a easier way to resolve this without using spark interval library with code example .
thanking you all in advance…
Pavel
2
I’m using sparkcore polled timer library and never had any issues for more than a year
do you have the code example for reference … am i using the wrong spark core library
Pavel
4
Have you tried searching?
Second one:
i think the spark interval library is timer interrupt based may be blyk is using the same timer …
I am using the Particle photon ?
I thing I found out I have been using Sparkintervaltime library instead of Sparkcorepolled timer.
Thanks Pavel…I just love blynk thanks
