i have the same problem.
i have built a home automation system, the lights can be turned on / off from the blynk app, but also from physical buttons in the rooms. when the arduino is connected to the network, everything works fine and reliable (i can control the lights from my phone and also with the physical buttons).
the problem is, when the arduino is not connected to the network (for example the network cable is unplugged), the system is not working at all, i can not even use the physical buttons.
system hangs in the setup(), at the Blynk.begin(auth); function: waits ~60 seconds, then restarts the arduino, and everything begins again. it never enters in the main loop() function.
i would like to bypass somehow this problem: if no internet connection, than execute loop(), without blynk.
also there is another problem, if i unplug the network cable during loop() runtime, after a while the program hangs, it not responds to physical buttons. i must plug the cable, or reset the arduino.
i use arduino adk + enc28j60 + uipethernet + blynk.
i used the code in the example you gave, but now it hangs during the Blynk.connect() function WITH NETWORK CABLE PLUGGED.
if instead Blynk.begin(auth) i’m using the code you gave, maybe there are other things to manually configure? i did not find a detailed documentation how to configure manually, but here: http://docs.blynk.cc/#blynk-firmware-virtual-pins-control-blynk_connected it says:
“You can also set up shields (WiFi, Ethernet) manually, and then call:
Blynk.config(auth);” so, maybe i’m missing something before call Blynk.config(auth)…
however, i do not understand, how could the “while” cycle measure the timeout, if it never gets executed, because the program hangs at Blynk.connect()?
My sketch extract is based on WiFi and for devices that are already connected to the internet with WiFiManager.
You need to adapt for ethernet access and as I don’t use ethernet you would have to post your working ethernet sketch if you want us to advise what changes you need to make.
/* if network cable not plugged, timeout is ~60 seconds, after that it reboots. i would like to bypass this (instead rebooting -> go to loop()), if there is no network connection.*/
@Costas , i’m not allowed to post more than 3 post in the same topic, so i try to edit this one.
so, i have tried the EXACT code you provided.
now it passes the Blynk.config(auth, “blynk-cloud.com”, 8442) function, but hangs in the Blynk.connect() , with the network cable plugged!
it does not enter in the “while” loop.
It connects longer than usual if anything is working, but connecting and syncing. If I deny ESP8266 connecting to AP, my code is working after 10 seconds approx. If I’ll allow — it reconnects and works again.
My code working from the start, if I reboot ESP8266, no more pauses on Blynk connecting.
Blynk.run() is designed this way that if it loses connectivity it will automatically try to reconnect you can have a look in source files. You would have to modify Blynk library or use what you have posted as last code which is fine btw.
there is no need to use float variable for timeout, its wrong, just use unsigned long, also mills() returns unsigned long so result of mills()/1000 is unsigned long, to get float you would have to cast both numbers to float. Secondly this is pointless:
This is function in Blynk library responsible for connecting:
bool connect(uint32_t timeout = BLYNK_TIMEOUT_MS*3) {
conn.disconnect();
state = CONNECTING;
uint32_t started = millis();
while ((state != CONNECTED) &&
(millis() - started < timeout))
run();
return state == CONNECTED;
You can clearly see there is timeout already there… just use it as Blynk.connect(timeout)
And btw your code is not hanging up on Blynk.connect() it just executes the check once or maybe not at all because you wrongly declared timeout float. you should just declare it as global variable float timeout; then later in setup assign (mills() / 1000)
I messed up last bit, what I meant is declare as unsigned long variable without initializing it:
unsigned long timeout;
rather than:
unsigned long timeout = mills() / 1000;
This variable most likely wont initialize properly as timers are not yet running (it’s initialized before setup happens?), this is actually good question but for sake of predictable results it should be done in setup(). If timers aren’t initialized it will be 0 anyway, kinda pointless right? Also in this case timeout doesn’t have to be global as it is used only in setup()
Yes timeout only needs to be declared in setup() not globally.
unsigned long timeout; is wrong though because you want the running time when setup reaches this point not zero. In some cases it can take MANY seconds to work through all the items in setup() e.g. with WiFiManager etc.
If it is declared as global it should be unsigned long timeout; as there is no point in initializing there a global variable with mills(), you assign mills()/1000 later in setup just before while loop. However if the variable is used as local in setup then you initialize and declare variable inline just before while loop like so: unsigned long timeout = mills() / 1000; (same as your last line), you probably misunderstood me as for the first part.
Anyway the whole thing with while loop is not needed as you can simply use Blynk.connect(3333); which will do the same.
hi!
thanks for clearing things up. i was asked to follow exact code examples, this is why i used ‘as is’.
unfortunately for the next days i will not have access to the arduino + ethernet modul. but later i will test your suggestion too, and announce if it works or not.
It’s a while condition not a timer interrupt so in this case you wont see timeout after 3ms but it will occur when run() finishes execution and at the same time while loop checked that it is executing for more than 3ms.
