New user. I am having trouble connecting to air board. Codebender was used to flash the auth code to the air board but I keep getting error that air board is offline. It does seem to drop the ble link pretty easily
Also buttons in blynk don’t correspond to onboard led pins 5 and 9
Any suggestions or just dump the air board and try something else…
Hi there, I am completely new to this game so forgive my ignorance. I have installed socat but I do not understand the concept of skipping server parameters. I am trying to run a command inmy mac terminal:
Hi, you probably want just to launch the blynk-ser script and not type “socat” before I think. I understand that server parameters are not needed if you just want to run local. On those points, the Blynk team should know much better.
