Can someone tell me, why I can´t change the timer interval from the timer, which calls Func_Mode_4 ???
The other loops should be called every 100ms, I only want to be able to adjust the interval to call void Func_Mode_4(){} with a slider widget on V26.
Sorry but it doesn´t help me really on. Can´t understand why it doesn´t works because the following sketch works fine. But there I call only one loop. There I am able to adjust the interval
There I get a value from a slider on v26. With it I want control the interval from a blinking led. For example if the value I get from slider is 10 and I call the loop every 100ms, a led on output blinks with a frequency of 1Hz, when value is 1 the led blinks with 100Hz.
Be careful if you select 10 from slider, then here you start the timer with repeat rate of 10mSec due to this activation:
timerBlinker = timer.setInterval(BlinkValue, Func_Mode_4);
Just tried. Instead of setting the slider from 1-10 is set it from 1-1000 but without success. The led usually blinks with the same frequenzy. I think there it doesn´t work because it become called three other timers at the same time
