Hello
i have a Arduino uno with a esp8266 on pin 4 and 5 (rx and tx)
i used the ESP8266_Shield example but when it connect on cloud give me this error: Buffer overflow
the script is
* Downloads, docs, tutorials: http://www.blynk.cc
* Sketch generator: http://examples.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to use ESP8266 Shield (with AT commands)
* to connect your project to Blynk.
* WARNING!
* It's rather tricky to get it working, please read this article:
* https://github.com/blynkkk/blynk-library/wiki/ESP8266-with-AT-firmware
* Change WiFi ssid, pass, and Blynk auth token to run :)
* Feel free to apply it to any other example. It's simple!
#include <ESP8266_Lib.h>
char auth[] = "a4283f686cff41e489******";
char ssid[] = "VodafoneMobileWiFi-599C69";
char pass[] = "*******7244";
//#define EspSerial Serial1
SoftwareSerial EspSerial(4, 5); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set console baud rate
// Set ESP8266 baud rate
and the dispaly is this:
19]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.4.6 on Arduino Uno
[603] Connecting to VodafoneMobileWiFi-599C69
[13625] AT version:0.;0.0.0(Jan 28 2016 15:10;17)
SDK vession:1.5.2(7eeeo
[14648] Failed to enable MUX
[14662] Failed to set STA mode
[36465] Ready (ping: 12ms).
[47106] Buffer overflow
[47107] Buffer overflow
Hello
doesn’t work . I tested with 4800, 9600 , 19200 etc etc
I had changed the boundrate of esp8266 before the lauch of this sketch with AT comand AT+UART_DEF=9600,8,1,0,0
i tested several time also with little delay from the virtualwite but doesn’t work and i testd also change the firmware on the Esp but the error is always Buffer overflow
could you help me?
* WARNING!
char auth[] = "a4283f686cff41e48902a115fdab2c13";
char pass[] = "LE7HL0xxxx";
// #include <SoftwareSerial.h>
// SoftwareSerial EspSerial(2, 3); // RX, TX
#define ESP8266_BAUD 9600
for (int(num)=0; num <10 ;num++)
{ Blynk.virtualWrite(V1, num);
Blynk.virtualWrite(V2, num);
___ __ __
/___/ v0.4.6 on Arduino Mega
[604] Connecting to VodafoneMobileWiFi-599C69
[3780] AT version:1.1.0.0(May 11 2016 18:09:56)
SDK version:1.5.4(baaeaebb)
Ai-Thinker Technology Co. Ltd.
Jun 13 2016 11:29:20
OK
[11077] +CIFSR:STAIP,"192.168.0.xxx"
+CIFSR:STAMAC,"60:01:94:0f:8f:e6"
[11086] Connected to WiFi
[22064] Ready (ping: 28ms).
[35446] Buffer overflow
[35447] Buffer overflow
[35448] Buffer overflow
@Faben you can’t have that nonsense in loop(). It states send values to the server at thousands of times a second. Study the examples to see how you send data to the server at intervals. PushData is the recommended example to start with and learn how SimpleTimer works.
For several time i use simple timer and now i added one RTC DS1307 and i connected 2 pin on SDA and SCL on pin 20 and 21 (Arduino MEGA).
The sketch was working fine till i met one error when i load the program by IDE 1.8.3
The error is like the the COM can’t comunicate with IDE. Is like when i keep open the monitor opened when i’m compiling and loading the sketch. The serial port on Arduinoi Mega are free. Only the Serial1 are busy for a ESP8266.
I made several test even restart the PC but sometime something lock the the IDE when it is compiling.
So is possible one confllict from RTC lib and the SimpleTimer lib?
If yes how can i set interval with only RTC lib like this command ?
[quote]
timer.setInterval(1000, myTimerEvent1);[/quote]
Thank you a lot
