BMP180, BH1750, SI7021- ESP8266 12e
He here is my temperature measurement. I using two ESP one for temp from outside by DHT. And another for temp from inside and lux and pressure.
Sketch:
#include <SI7021.h>
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <BH1750.h>
BH1750 lightMeter;
char auth[] = "";
SI7021 sensor;
#define I2C_SCL 12      //D6
#define I2C_SDA 13     //D7
Adafruit_BMP085 bmp;
float dst, bt, bp, ba;
char dstmp[20], btmp[20], bprs[20], balt[20];
bool bmp085_present = true;
  Blynk.begin(auth, "", ""); //insert here your SSID and password
 Wire.begin(I2C_SDA, I2C_SCL);
if (!bmp.begin()) {
  Serial.println("Could not find a valid BMP085 sensor, check wiring!");
  //while (1) {}
  timer.setInterval(2000L, sendUptime);
  lightMeter.begin();
  //sensor.begin(SDA,SCL);
void sendUptime()
float temperature = sensor.getCelsiusHundredths();
float humidity = sensor.getHumidityPercent();
Blynk.virtualWrite(5, (float)temperature/100, 2);
Blynk.virtualWrite(6, humidity); // virtual pin
  uint16_t lux = lightMeter.readLightLevel();
  Blynk.virtualWrite(4, lux);
  float bp =  bmp.readPressure();
  Blynk.virtualWrite(9,(float)bp/100,2);
  float ba =  bmp.readAltitude();
  Blynk.virtualWrite(7, ba);
  float bt =  bmp.readTemperature();
  Blynk.virtualWrite(12, bt);
  float dst =  bmp.readSealevelPressure(520)/100;
  Blynk.virtualWrite(13, dst);
Here is video with CO2 sensor.
VIDEO
