Hi there, it´s me again
I am playing with another sensor which I want to run on battery with deepsleep and show measurements in the Blynk mobile app.It´s BME280 sensor
I am able to see measured values in serial monitor of IDE (connected with ESP8266-12E for the beginning) but I am not able to implement Blynk code so I am not able to see it in my phone app. I understand it´s noob task, but really coding and me are not friends
I tried to put my BME280 code into my existing code posted here https://community.blynk.cc/t/what-is-wrong-with-my-project-battery-not-lasting-as-long-as-expected/17716/40?u=helpfinder
but no success maybe some of you can help me here? Thank in advance
This is my BME280 code wotking with serial monitor
This is a library for the BME280 humidity, temperature & pressure sensor
Designed specifically to work with the Adafruit BME280 Breakout
----> http://www.adafruit.com/products/2650
These sensors use I2C or SPI to communicate, 2 or 4 pins are required
to interface. The device's I2C address is either 0x76 or 0x77.
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Limor Fried & Kevin Townsend for Adafruit Industries.
BSD license, all text above must be included in any redistribution
// Sketch modified by Steve Spence - http://arduinotronics.blogspot.com
// converted to American units and added Dew Point and Heat Index calculations
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
//#define BME_SDA D3
//#define BME_SDL D4
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme; // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
unsigned long delayTime;
Serial.println(F("BME280 test"));
bool status;
// default settings
status = bme.begin();
if (!status) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
Serial.println("-- Default Test --");
delayTime = 1000;
Serial.println();
printValues();
delay(delayTime);
void printValues() {
Serial.print("Temperature = ");
Serial.print(bme.readTemperature());
Serial.println(" *C");
Serial.print("Pressure = ");
Serial.print(bme.readPressure() / 100.0F);
Serial.println(" hPa");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
Serial.print("Humidity = ");
Serial.print(bme.readHumidity());
Serial.println(" %");
Serial.println();
My second question is related if somebody has experience with BME280 connected to the ESP8266-01 only with GPIO0 and GPIO2 (without need to solder small pins, to solder GPIO16 for deepsleep is enough I would say).
I will try to use ESP8266-07 which has more pins but I have to chedk if there is easy way to probram it without builting complex circuits with buttons etc.
Thank you
