Blynk-ser.bat ERROR
when I try to run the blynk-ser.bat file I get this error: “Socket(): getprotobyname(“tcp”) ERROR Unknown error (11004)”
Can someone tell me what i’m doing wrong?
@Gunner
@dylans Welcome to Blynk.
Are you using Windows PC as implied by the .bat file?
Did you start it from within the Arduino IDE or directly from the scripts folder - If directly, then what did you make changes to in the file?
There is also more info in the Documentation here: http://docs.blynk.cc/#hardware-set-ups-arduino-over-usb-no-shield
Same situation!
System: Windows 7 pro (.bat file)
