Blynk Remote control 433.92 MHz Plugs with Auto Router power on when no access to Blynk Server
First off this project was created using other peoples ideas, assistance and code:
What this project does is allows one to use Blynk to remote control wireless plugs & allow a single plug to turn on if off by checking to see if it’s connected to the blynk server. I am using this to reboot my router.
How to pair the plugs - get the plug light flashing ready for pairing and just toggle the button in blynk you want to assign the plug.
This is a modification of the project done by bitluni 2016 - http://youtube.com/bitlunislab
Project YouTube Video - https://www.youtube.com/watch?v=O_cgfj6SiTY
this allows 433.92MHZ RF plugs to be oporated by Blynk and ESP8266
biluni decoded the ON / OFF bytes and without his help this would not have been possible
Thank you to Costas for the Checkserver Blynk Code [SOLVED] How to run Blynk.run() only when WiFi connection is established - #4 by FebryKN
Please if you use this code and or project include the above people as mentioned without their support and knowledge this would not be possible
Materials:
Mains Plugs:
ESP8266:
RF-wireless-transmitter-module:
This is the code I used:
#include “ESP8266WiFi.h”
#include “BlynkSimpleEsp8266.h”
#include “RF.h”
#include “SimpleTimer.h”
const int ID1 = 2800; //0…1048575 ID umber can be used
const int ID2 = 2801; //0…1048575 ID umber can be used
const int ID3 = 2802; //0…1048575 ID umber can be used
const int ID4 = 2803; //0…1048575 ID umber can be used
const int ID5 = 2804; //0…1048575 ID umber can be used
const int OFF = 0b0011; // code to turn unit on
const int ON = 0b1100; // code to turn unit off
const int CHANNEL = 0; //0…1
const int RF_OSC = 200; //rf signal cycle legth(µs). 200 works for me
const int RF_OUT = D2; //Pin out ESP8266
char auth = “…”;
// Set password to “” for open networks.
char ssid = “…”;
char pass = “…”;
bool Connected2Blynk = false;
pinMode(RF_OUT, OUTPUT);
Blynk.connect(3333); // timeout set to 10 seconds and then continue without Blynk
// Wait until connected
Serial.println(“Connected to Blynk server”);
timer.setInterval(11000L, CheckConnection); // check if still connected every 11 seconds
//Setup for V1 switch
BLYNK_WRITE(V1)
if (param.asInt() == 0)
for(int i = 0; i < 5; i++)
rfWriteCode(RF_OUT, RF_OSC, ID1, OFF); //off (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, OFF = 0b0011 code for off)
rfWriteCode(RF_OUT, RF_OSC, ID1, ON); //on (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, ON = 0b1100 code for on)
//Setup for V2 switch
BLYNK_WRITE(V2)
rfWriteCode(RF_OUT, RF_OSC, ID2, OFF); //off (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, OFF = 0b0011 code for off)
rfWriteCode(RF_OUT, RF_OSC, ID2, ON); //on (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, ON = 0b1100 code for on)
//Setup for V3 switch
BLYNK_WRITE(V3)
rfWriteCode(RF_OUT, RF_OSC, ID3, OFF); //off (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, OFF = 0b0011 code for off)
rfWriteCode(RF_OUT, RF_OSC, ID3, ON); //on (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, ON = 0b1100 code for on)
//Setup for V4 switch
BLYNK_WRITE(V4)
rfWriteCode(RF_OUT, RF_OSC, ID4, OFF); //off (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, OFF = 0b0011 code for off)
rfWriteCode(RF_OUT, RF_OSC, ID4, ON); //on (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, ON = 0b1100 code for on)
//Setup for V5 switch
BLYNK_WRITE(V5)
rfWriteCode(RF_OUT, RF_OSC, ID5, OFF); //off (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, OFF = 0b0011 code for off)
rfWriteCode(RF_OUT, RF_OSC, ID5, ON); //on (RF_OUT = Pin ESP8266 output to RF Sender, RF_OSC is rf signal cycle legth(µs)200 , ID1 is unit ID 0…1048575 new id for each unit, ON = 0b1100 code for on)
void CheckConnection(){
Connected2Blynk = Blynk.connected();
if(!Connected2Blynk){
Serial.println(“Not connected to Blynk server”);
rfWriteCode(RF_OUT, RF_OSC, ID3, ON); //on (This is the command to turn the router on ID3 on)
Create a file called RF.h
put the below code in the file and save
put the file in folder with the Sketch ino file
Released under Creative Commons Attribution 4.0
by bitluni 2016
CC BY 4.0 Deed | Attribution 4.0 International | Creative Commons
Attribution means you can use it however you like as long you
mention that it’s base on my stuff.
I’ll be pleased if you’d do it by sharing http://youtube.com/bitlunislab
inline void rfPreamble(int pin, int t)
int m = micros();
digitalWrite(pin, 1);
while(micros() - m < t);
digitalWrite(pin, 0);
while(micros() - m < t * 32);
inline void rfWriteBit(int pin, int t, int b)
int m = micros();
if(b)
while(micros() - m < t * 3);
while(micros() - m < t * 4);
void rfWriteCode(int pin, int t, int code, int data)
rfPreamble(pin, t);
for(int i = 0; i < 20; i++)
rfWriteBit(pin, t, code & 1);
code >>= 1;
for(int i = 0; i < 4; i++)
rfWriteBit(pin, t, data & 1);
data >>= 1;
Shared Blynk Project:
@erasma I checked your QR code and it worked fine. Not checked your code yet. We do a lot of work with RF devices and we have done quite a bit of work on cloning RF codes. We started way back in the Nano days but the minimal storage meant it was almost impossible to build a decent cloner.
With the massive memory now available with ESP’s we are able to build a much more robust cloner. Over the years many people have decoded RF signals and made the information available. The benefit of a decent cloner is that it should work for all 433.92 MHz devices, excluding rolling codes.
We still have more work to do on the project but hope to be able to release the product at some point.
