Hello everybody
I’ve tried Blynk Library’s C++ approach, made by @Costas
[Using C++ on a Raspberry Pi with Blynk]
I’m only interested in Virtual Pins, so, i compiled against “target=linux” .
It works fine in my Linux PC (Ubuntu 16.04 32bit) as well as in my tiny i.MX233 linux board (archlinux, kernel 2.6.35).
Then i had the idea to export common Blynk functions to a shared object library (name it libblynk.so)
I started with main.cpp example which modified as follows
* @file main.cpp
* @author Volodymyr Shymanskyy
* @license This project is released under the MIT License (MIT)
* @copyright Copyright (c) 2015 Volodymyr Shymanskyy
* @date Mar 2015
* @brief
#define BLYNK_PRINT stdout
#include <BlynkApiLinux.h>
#include <BlynkSocket.h>
#include <BlynkOptionsParser.h>
static BlynkTransportSocket _blynkTransport;
BlynkSocket Blynk(_blynkTransport);
#include <BlynkWidgets.h>
void virtualWrite(int handle,double value){
Blynk.virtualWrite(handle,value);
void virtualWrite(int handle,char * value){
void setProperty(int handle, char * property, char * value){
Blynk.setProperty(handle,property,value);
void begin(const char *auth,const char *serv,uint16_t port){
Blynk.begin(auth, serv, port);
void run(){
int main(int argc, char* argv[])
const char *auth, *serv;
uint16_t port;
auth="e72fd035f50b44d08e43b92356b00975";
serv="blynk-cloud.com";
port=8442;
//parse_options(argc, argv, auth, serv, port);
//printf(serv);
while(true) {
run();
return 0;
At this point, i’m interested to expose in the library only some basic functions for testing, as per main.h below
/*--- main.h---*/
typedef unsigned int uint16_t;
extern void virtualWrite(int,double);
extern void virtualWrite(int,char *);
extern void setProperty(int, char *, char *);
extern void begin(const char *,const char *,uint16_t);
extern void run();
In order to compile and link, i made the following script
#!/bin/bash
g++ -I ../src/ -I ./ -fPIC -DLINUX -c -O3 -w main.cpp -o main.o
g++ -I ../src/ -I ./ -fPIC -DLINUX -c -O3 -w BlynkDebug.cpp -o BlynkDebug.o
g++ -I ../src/ -I ./ -fPIC -DLINUX -c -O3 -w ../src/utility/BlynkHandlers.cpp -o ../src/utility/BlynkHandlers.o
g++ -I ../src/ -I ./ -fPIC -DLINUX -c -O3 -w ../src/utility/BlynkTimer.cpp -o ../src/utility/BlynkTimer.o
g++ -shared -o libblynk.so main.o BlynkDebug.o ../src/utility/BlynkHandlers.o ../src/utility/BlynkTimer.o
It ends up with the libblynk.so file created, so, i guess everything is fine!
Now, it’s time to link it with an executable just to test it
For this, i prepare test.cpp as follows
#include <main.h>
uint16_t port;
port=8442;
while(true) {
run();
return 0;
Finally i compile as follows
g++ -I. -L. -o testso test.cpp -lblynk
And i get the following response
/tmp/ccmidSjd.o: In function `main':
test.cpp:(.text+0x33): undefined reference to `begin(char const*, char const*, unsigned int)'
collect2: error: ld returned 1 exit status
Any idea on what’s going on?
Best Regards
Kostas
