what ip can you be a bit clear i did video on tasker its that almost similar ?
For india, ip is 188.166.177.186
In URL for ifttt.
Instead of blynk-cloud.com
Use Ip address.
I am wondering that you haven’t faced geo Dns issue.
Ping me with your email id il share my contact no
What should i type to use do button
I currently tried
http://blynk-cloud.com/token/update/pin
Doesn’t work
I choose request type as put
Application/json
Whats wrong
Which ip should i use
I currently tried
Doesn’t work
Application/json
Whats wrong
Ip for india is 188.166.177.186
How should i enter please tell format
Http://ip/authtoken/update/pin
??, is this format??
How do you guys know the ip like for india ip is 188.166.177.186??
Just ping to blynk-cloud.com.
@Dmitriy.
I have question
Does this ips of server are static or dynamic??
How many servers Blynk have??
Its works likr charm with do button doesn’t work with ifttt recipe help
http://188.166.177.186/xxxxx/update/D26
What should i do
Should i try replacing ip with blynk cloud one
Io one is working for do button not for ifttt recipe???
@Dmitriy
@Pavel
http://blynk-cloud.com /xxxx/update/D26
I tried this even this is not working with ifttt
But when i replace by ip address as mentioned earlier works with do not with ifttt
I tried changing [<<<0>>>] didn’t worked
Tried even this [“0”]
@Dmitriy
@Pavel
Dear sir when i tried doing this works like charm
When i created same thing with dk button app o android
http://188.166.177.186/xxxxx/update/xxx
Same thing does not work on ifttt can u please help??
Try to use virtual pins. Does that help?
Works fine with virtual pins thanks
not able to get recipe option in ifttt app on Android / IOS … its showing my applet .
After select create a new applet,try to pick Button widget
as “IF” ,than select Maker
as “That”.Now you can see Make a web request
option to fill in.
