Blynk HTTP Api - Add and Write value to table row
I’ve read on this site how to get and write value for a widget.
http://docs.blynkapi.apiary.io/
For the value widget/button widget, it’s worked no problem.
http://blynk-cloud.com/auth_token/update/pin?value=value
But when i trying to add new row and write the value using HTTP Api.
(the right code is:
Blynk.virtualWrite(V1, "add", rowIndex, "My Event", "My Value");
Do you know how i can do it?
Thanks in advance!
Regards,
Hello. New need just to send multiple values in http request.
v1?value=add&value=rowIndex&value=My%20Event&value=My%20Value
@Dmitriy thank you, it works now.
Just another question!
Hope you can give a instruction.
In nodejs, how we do to add a row like in C?
Blynk.virtualWrite(V1, "add", rowIndex, "My Event", "MyValue");
It’s worked when i tried this code
V2.on('write', function() { V1.write('clr');});
but not this one:
V1.write("add",rowIndex, "My Event", "MyValue");
or
V2.on('write', function() {V1.write("add",rowIndex, "My Event", "MyValue");})
I don’t know what is wrong here.
I found the solution, to add row in nodejs:
V1.write(["add",rowIndex,"My Event","MyValue"]);
