Dear Friends,
I have a couple of Raspberry Pi3 and Zero-W and accepted to join the Particle’s open beta program. I trying to do my first steps to Particle WebIDE. Is there instructions how to do? I mean, how to get working with Blynk inside the Particle WebIDE using Raspberry Pi… I have already registered my RPi so how to proceed from there? Is there any good how to to follow?
For the RPi, I think you have to treat is as one would normally with Blynk… search this forum for what few examples there are. But I don’t know if Particle WebIDE is using Javascript or somthing else, or if it is just a different way of accessing the RPi.
PS, Out of curiosity, I did try installing it on my older RPi B ver2, but it now locks up with no connection, mouse or KB control, so I need to wipe out the SD card and reinstall Raspbian… I think I will stick with WinSCP and Notepad++
Dear @Gunner,
first of all thanks for tyour answer and the help offered. Actually, I got my impression that Mr. @vshymanskyy confirms to me that it is possible to use Blynk under Particle’s WebIDE. See the quotation bellow:
So I am looking the way to have Blynk under Particle, without success yet.
@mikekgr I agree, I think it should be possible to program Blynk from Particle’s WebIDE… I just meant that I don’t think we will find directions or direct assistance for any install issues or follow through assistance…on this forum
I haven’t reinstalled my RPi yet, so still unsure if I will give Particle’s WebIDE another shot or not
Hey - there’s nothing special about Blynk library comparing with other Particle WebIDE libraries - so just continue as usual. If you don’t know how to proceed - probably it’s described in Particle documentation.
@Gunner@vshymanskyy
Thanks a lot guys. I will try to get some help from the particular particle forum. If /when I achieve something, I will let you know.
Dear @vshymanskyy,
I have reached in the “final stage” to run the bellow code sample but I can not substitute SimpleTimer with the SparkCorePolledTimer library. Can you give me an example, how to modify the bellow snippet?
Thanks in advance.
#include <SparkCorePolledTimer.h>
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
NOTE: It is recommended to use SparkCorePolledTimer library
to make periodic actions (similar to SimpleTimer on Arduino).
Blynk using a LED widget on your phone!
App project setup:
LED widget on V1
WARNING :
For this example you'll need SimpleTimer library:
https://github.com/jfturcot/SimpleTimer
Visit this page for more information:
http://playground.arduino.cc/Code/SimpleTimer
/// #define BLYNK_PRINT Serial
#include "blynk.h"
WidgetLED led1(V1);
///SimpleTimer timer;
///SparkCorePolledTimer updateTimer(1000);
// V1 LED Widget is blinking
void blinkLedWidget()
if (led1.getValue()) {
led1.off();
///Serial.println("LED on V1: off");
led1.on();
///Serial.println("LED on V1: on");
///Serial.begin(9600);
delay(5000); // Allow board to settle
Blynk.begin(auth);
/// timer.setInterval(1000L, blinkLedWidget);
/// timer.run();
P.S. Although I used tree back tics ``` at start and stop code the code did not formated. Why?
