Hlo Blynk Employees i think you need to prepare one ppt for blynk server how controlling happend with phone thats good for your company plz focus on it
I need to make a weekday timer ā¦ is there a way you can help me ? Iām new to arduino and Blynk ā¦ please contact me vivianatej9@gmail.com
@Vivianatej9 This forum is for Blynk users to share and assist other Blynk users with ideas and guidance.
We are not a for-hire code factory, nor is begging for code considered acceptable, here in the open forum nor via private messaging, as you have also been doing.
Please cease from sending out these types of requests or you risk getting blocked from the forums.
I just needed help with my project ā¦ but thatās for your time .
Hi, Iām struggling with the bridge widget!
What I need seems pretty simple but canāt make it work, the Blynk library examples arenāt helping.
I want to connect two Arduino boards via the bridge widget and that whenever a led in board A is ON turn an led in board B ON. And whenever the led of board A is OFF the led of board B is OFF.
I would really appreciate some help with the code, Iām completely stuck!
Thanks!!
Code Arduino A
#define BLYNK_PRINT SwSerial
char auth[] = "c4338d1814324794ba0802364381f740"; //Arduino A
WidgetBridge bridge1(V1);
static bool value = true;
BLYNK_CONNECTED() {
bridge1.setAuthToken("4059dde6593b444592d25b53c36089ea"); // Arduino B
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
if (value) {
bridge1.digitalWrite(9, HIGH); // Digital Pin 9 on the second board will be set HIGH
bridge1.virtualWrite(V5, 1); // Sends 1 value to BLYNK_WRITE(V5) handler on receiving side.
bridge1.digitalWrite(9, LOW); // Digital Pin 9 on the second board will be set LOW
bridge1.virtualWrite(V5, 0); // Sends 0 value to BLYNK_WRITE(V5) handler on receiving side.
// Toggle value
value = !value;
Code Arduino B
char auth[] = "4059dde6593b444592d25b53c36089ea";
BLYNK_WRITE(V5){
int pinData = param.asInt(); // pinData variable will store value that came via Bridge
// to avoid delay() function!
@Edu_Ferrer is Arduino A being disconnected from the server as you look to be sending far too much data i.e. 1000ās of times a second.
Before the line value = !value;
add:
delay(1000); // NEVER USE DELAY WITH BLYNK, USE BLYNK TIMER
The delay(1000)
is only for test purposes to see if bridge works. Once you have it running study SimpleTimer on the Arduino site as this is how BlynkTimer works and must be used in place of the delay() function.
Hello there,
Iām programming a nodemcu without the nodemcu, I mean, I have not right now it but I have too many free timeā¦
I have to send multiples values to blynk, im reading them from softserial port (in this moment I have 20 values) I have to send them to different widgets, it is possible to send them with 20 Blynk.virtualWrite one after the other?
Blynk.virtualWrite (V1, variable1);
Blynk.virtualWrite (V2, variable2);
Blynk.virtualWrite (V3, variable3);
ā¦
I set the BLYNK_MSG_LIMIT to 100 and Iām running a local server with also a limit of 100 messages per second.
Could those 20 messages overflow the server or the hardware?
Thanks!
So 1 message allowed every 0.01 seconds or every 10ms.
Maybe sandwich a delay(11)
between each virtualWrite.
I have found that itās not wise to go beyond 3 or 4 consecutive virtualWrites.
Well, should be good to know if the overflow is triggered each second, or each 10ms orā¦ should be a watchdogā¦ the sandwitch could be so each 3 virtualWrites?
I think I have to test it, I like test and error procedure! But if not nodemcu, not test and no error
Thanks!
This time Iām doing tests with webhooksā¦
using this code in my project:
#define BLYNK_MAX_READBYTES 1024
BLYNK_WRITE(V0)
Serial.println("WebHook data:");
Serial.println(param.asStr());
BLYNK_WRITE(V10)
if (param.asInt())
//Blynk.virtualWrite(V0, "https://raw.githubusercontent.com/blynkkk/blynk-library/master/extras/logo.txt");
Blynk.virtualWrite(V0, "https://api.sunrise-sunset.org/json?lat=41.58491773&lng=1.612949&date=today");
I receive this:
[15062] <[14]o:[00]Pvw[00]0[00]https://api.sunrise-sunset.org/json?lat=41.58491773&lng=1.612949&date=today
[15206] >[14]o[1E|00|07]
[15206] >vw[00]10[00]0
[25162] <[06|00|02|00|00]
[25210] >[00|00|02|00|C8]
[32972] >[14]d[A8|00|07]
[32973] >vw[00]10[00]1
[32973] <[14]d[A8|00]Pvw[00]0[00]https://api.sunrise-sunset.org/json?lat=41.58491773&lng=1.612949&date=today
[33179] >[14]uV[00|07]
[33179] >vw[00]10[00]0
[43162] <[06|00|03|00|00]
[43262] >[00|00|03|00|C8]
But no data received even that trying in the explorer all seems working.
If I use the Blynk logo url, it works perfectā¦
V0 = webhook URL=/pin/ METHOD=GET CONTENT TYPE=application/json BODY=(Cant write nothing here using GET)
V10 = button
Searching in Blynk I found the same issue, itās set as [SOLVED] but there is no solution insideā¦ @Costas, did you help him by PM? [Solved] Webhook problem
Thanks!
@darkmoon the power of the Webhook widget is the ability to easily modify the API call.
Manually entering the url in the widget is a pain so itās better to email the url to yourself and paste it into the widget.
Once you have allocated a āpin arrayā you can easily change the array to get revised data without changing the url.
Just knocked up a project for your call and the original call you referred to.
Data from Serial Monitor is:
41.58
1.61
{"results":{"sunrise":"4:28:04 AM","sunset":"7:12:19 PM","solar_noon":"11:50:11 AM","day_length":"14:44:15","civil_twilight_begin":"3:55:47 AM","civil_twilight_end":"7:44:36 PM","nautical_twilight_begin":"3:15:07 AM","nautical_twilight_end":"8:25:16 PM","astronomical_twilight_begin":"2:28:38 AM","astronomical_twilight_end":"9:11:45 PM"},"status":"OK"}
20151106
1358
20108
{"id":380876,"matchnr":20108,"datetime":"2015-11-06T19:00:00.000Z","matchtypeid":1,"teams":[{"id":1067751,"name":"DOV 4","teamplayers":[{"id":2137382,"name":"M. Petiet","subst":0},{"id":3294276,"name":"S. de Hoogt","subst":0},{"id":3413244,"name":"J. van der Aar","subst":0},{"id":3829013,"name":"D. Bendter","subst":0},{"id":4060662,"name":"R. Holscher","subst":0}],"matchplayers":[{"id":4060662,"name":"R. Holscher","dbl":1},{"id":3413244,"name":"J. van der Aar","dbl":1},{"id":3294276,"name":"S. de Hoogt","dbl":0}]},{"id":1067383,"name":"Stede Broec 5","teamplayers":[{"id":2220119,"name":"J. Broer","subst":0},{"id":3031636,"name":"R. Pronk","subst":0},{"id":3031644,"name":"J. Neuvel","subst":0},{"id":3033183,"name":"P. Sijm","subst":0},{"id":3293759,"name":"T. Buijsman","subst":0}],"matchplayers":[{"id":3293759,"name":"T. Buijsman","dbl":1},{"id":3033183,"name":"P. Sijm","dbl":1},{"id":3031644,"name":"J. Neuvel","dbl":0}]}]}
Sketch is:
// WebhookNEW.ino https://community.blynk.cc/t/blynk-for-beginners-and-help-with-your-project/10000/36
// and https://community.blynk.cc/t/solved-webhook-problem/10279/20 by Costas 21 May 2017
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
char server[] = "blynk-cloud.com";
// reference https://ttapp.nl/sbapi?getmatch&date=20151106&clubid=1358&matchnr=20108
int datum = 20151106;
int clubid= 1358;
int matchnr= 20108;
// reference https://api.sunrise-sunset.org/json?lat=41.58491773&lng=1.612949&date=today
float latitude = 41.58491773;
float longitude = 1.612949;
Serial.println("\nStarted");
Blynk.begin(auth, ssid, pass, server);
BLYNK_WRITE(V1){ // Webhook enter https://ttapp.nl/sbapi?getmatch&date=/pin[0]/&clubid=/pin[1]/&matchnr=/pin[2]/
if (param.asInt() == 1) {
Blynk.virtualWrite(V2,datum,clubid,matchnr);
Serial.println(datum);
Serial.println(clubid);
Serial.println(matchnr);
BLYNK_WRITE(V2){ // Webhook button for https://ttapp.nl/sbapi?getmatch&date=20151106&clubid=1358&matchnr=20108
String webhookdata = param.asStr();
Serial.println(webhookdata);
BLYNK_WRITE(V0){ // webhook for sunrise https://api.sunrise-sunset.org/json?lat=/pin[0]/&lng=/pin[1]&date=today
BLYNK_WRITE(V3){ // Webhook button for https://api.sunrise-sunset.org/json?lat=41.58491773&lng=1.612949&date=today
Blynk.virtualWrite(V0,latitude, longitude);
Serial.println(latitude);
Serial.println(longitude);
Still no luckā¦
[121504] <[14]55[00|11]vw[00]0[00]41.585[00]1.613
41.58
1.61
[121658] >[14]][AE|00|07]
[121658] >vw[00]10[00]0
could be some configuration on local server side?
There are webhook settings in server.properties, take a look and see if you find anything.
I donāt know whats happening with this url, but I tried with a different one and it worksā¦ test again with first one and still donāt workā¦ soā¦ now itās working
Thanks again @Costas.
@darkmoon count the characters in each json with Notepad++ (or similar) and ensure READBYTES is before the Blynk libraries in your sketch.
