Dear all,
we made first ready to use Blynk documentation - http://docs.blynk.cc/
Please check it and tell us what do you think. Any feedback is welcome.
Dear all,
Nice work!!!
will be a great help.
Jtalhate
I donât see anything in the documentation tab??
an empty black sidebar with an equally empty white page
Is it me or my Chrome on OSX 10.7.5?
RDG
After opening my inspector i saw that âPrivacy badgerâ blocked cdn.rawgit.com.
After giving that access all went fine thanks for the quick reply.
RDG
I went through the documentation and I think the following are typoâs. Most of them are not critical, but I though it would be good to give the feedback anyway.
So need to write code for simple things like LED, Relay control and analog sensors
should be
No need to write code for simple things like LED, Relay control and analog sensors.
It is better version of Value Display
should be
It is a better version of âValue Displayâ
Next formatting options supported:
should be
Next formatting options are supported:
Allows also to send any string to your hardware.
should be
Also allows to send any string to your hardware.
Ardiono Core
should be
Arduino Core
so there is no practical limits
should be
so there are no practical limits
Calling virtualWrite attempts to sent the value to the network immediately.
should be
Calling virtualWrite attempts to send the value to the network immediately.
One more, (itâs not a typo, but copy/pasto) :
BLYNK_READ_DEFAULT()
This redefines the handler for all pins that are not covered by custom BLYNK_WRITE functions.
should be
This redefines the handler for all pins that are not covered by custom BLYNK_READ functions.
@Strooom wow, thank you so much. Fixed. Please send me PM with your email so I could give you free energy for help.
One more:
BLYNK_READ(V0)
Blynk.virtualWrite(v0, newValue);
I think it should be V0 io. v0 as vars are case-sensitive
Whatâs the distinguish about âBLYNK_READ_DEFAULT()â and âBLYNK_READ(vPIN)â
Could you give me some example or explation? thank you.
I donât understood the Doc about this website.
@Yangfeng here is example with use case - https://github.com/blynkkk/blynk-library/blob/master/examples/More/PrintAllVirtual/PrintAllVirtual.ino
You can also use search for similar question.
