A little overview of my project. I’m making a wireless thermometer for smoking meats on a Big Green Egg. I currently have an iGrill which only has Bluetooth connectivity, which presents range issues. Here is my hardware progress thus far.
Hardware
Arduino Nano ATmega328
ESP8266-12
(Note: The ESP came with the latest AT build installed. I did not have to flash backwards to legacy firmware versions like many others users here have suggested. I may have gotten lucky)
Problem
I recently added the OLED screen picture above, and I’ve lost connectivity to Blynk with the addition of the Adafruit libraries. I’ve come to a point where I’m not sure what else to troubleshoot, so I’m hoping for some direction. My sketch is approaching the flash limit at about 87% storage space used and it suggests there may be stability issues. I’m hoping that’s not the problem. Below are versions 1.3 which works perfectly, and version 1.4 where I have issues. I pinpointed that connectivity issues happen by removing all the Adafruit code to just when the screen is defined with
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
If all the screen code is commented out, but the Adafruit libraries are included it works as well. Does anyone have any thoughts or suggestions?
1.3
VERSION Thermometer 1.3
Arduino Nano connected to ESP8266-12 Hard Serial
//#define BLYNK_DEBUG
//#define BLYNK_PRINT Serial
#include <ESP8266_HardSer.h>
#include <BlynkSimpleShieldEsp8266_HardSer.h>
#include <SimpleTimer.h> //Simple Timer Library`// Set ESP8266 Serial object
#define EspSerial SerialESP8266 wifi(EspSerial);
char auth[] = “xxxx”;
WidgetLED led1(V4);
WidgetLED led2(V5);
WidgetLED led3(V6);
WidgetLED led4(V7);int Probe[4] = {0,0,0,0};
double Temp[4] = {0,0,0,0};
int LED[4] = {0,0,0,0};
int i = 0;SimpleTimer timer; //Create a Timer object called “timer”
// Set console baud rate
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);analogReference(EXTERNAL);
Blynk.begin(auth, wifi, “xxx”, “xxxx”);
timer.setInterval(2000, sendTemperatures);
timer.setInterval(1333, sendLED);}
void sendTemperatures()
Blynk.virtualWrite(V0, int(Temp[1]));
Blynk.virtualWrite(V1, int(Temp[2]));
Blynk.virtualWrite(V2, int(Temp[3]));
Blynk.virtualWrite(V3, int(Temp[4]));}
void sendLED()
led1.setValue(int(LED[1]));
led2.setValue(int(LED[2]));
led3.setValue(int(LED[3]));
led4.setValue(int(LED[4]));
}void loop()
timer.run();Probe[1] = analogRead(A0);
Probe[2] = analogRead(A1);
Probe[3] = analogRead(A2);
Probe[4] = analogRead(A3);for(int i =1; i < 5; i++)
{if((Probe[i])<421) { Temp[i] = -61.3*log(Probe[i])+488.4; LED[i] = 255; } if(420<(Probe[i]) && (Probe[i]<1022)) { Temp[i] = (-0.116*Probe[i])+168.8; LED[i] = 255; } if((Probe[i])>1022) { Temp[i] = 0; LED[i] = 0; }
1.4
* VERSION Thermometer 1.4
Arduino Nano Connected to ESP8266-12 Hard Serial
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
char auth[] = "xxx";
WidgetLED led1(V4);
WidgetLED led2(V5);
WidgetLED led3(V6);
WidgetLED led4(V7);
int i = 0;
int j = 0;
SimpleTimer timer; //Create a Timer object called "timer"
Blynk.begin(auth, wifi, "xxx", "xxx");
//timer.setInterval(3667, sendOLED);
delay(50);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.display();
delay(2000);
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.println("Blynk.begin");
display.println("Connecting");
display.display();
void sendLED()
void sendOLED()
display.print("AMB: ");
display.print(Temp[1]);
display.println(" F");
display.print("P1: ");
display.print(Temp[2]);
display.print("P2: ");
display.print(Temp[3]);
display.print("P3: ");
display.print(Temp[4]);
display.display();
delay(5000);
display.startscrollright(0x00, 0x0F);
delay(5000);
if((Probe[i])<421)
LED[i] = 255;
LED[i] = 255;
if((Probe[i])>1022)
Temp[i] = 0;
LED[i] = 0;
