Big HEX file (sketch uses 60% memory in UNO)
Why does simple code take up 60% of the memory of arduino uno?
Is it possible to optimize the Hex file?
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
// Select your modem:
//#define TINY_GSM_MODEM_SIM800
#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
const char auth[] = "____________________________________";
// Your GPRS credentials
// Leave empty, if missing user or pass
const char apn[]  = "internet";
const char user[] = "";
const char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(7, 8); // RX, TX
TinyGsm modem(SerialAT);
  // Set console baud rate
  // Set GSM module baud rate
  SerialAT.begin(9600);
  delay(3000);
  modem.restart();
  // Unlock your SIM card with a PIN
  //modem.simUnlock("1234");
Скетч использует 19276 байт (59%) памяти устройства. Всего доступно 32256 байт.
Глобальные переменные используют 608 байт (29%) динамической памяти, оставляя 1440 байт для локальных переменных. Максимум: 2048 байт.
this mainly because of the used libraries , which has alot of code but not appearing to you in the sketch.
also not that Arduino UNO has a very small space for your FW comparable to other boards like ESP8266-12.
@russo mostly this is not Blynk itself but low level connection handling. Here is more info - Arduino Blynk library static memory footprint report
Maybe @vshymanskyy can make few more updates.
