@Costas Throws the same exception in terminal, I also deleted the blynk part in one of my tests, currently only trying to instance the darn sensor…
Thanks again for the help!!
@raul I was able to obtain a broadly similar error message to yours with the following syntax (no sudo) for w1.js
pi@raspberrypi:~ $ NODE_DEBUG=fs node w1 <token>
[ '28-0004412479ff' ]
Actual temp: 20.75 °C
(node:2888) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Could not set data gpio pin
Temp changed: 20.75 °C
Temp changed: 20.812 °C
Temp changed: 20.875 °C
However as you will see, my system carries on regardless and provided the ID and temperature readings.
You might also want to try the following, which will provide details of the modules being loaded. If you paste your results I can compare them with mine.
This is the output after editing out the setGpioData
pi@raspberrypi:/usr/local/lib/node_modules/blynk-library $ sudo NODE_DEBUG=fs,module node w1 <token>
MODULE 1320: looking for "/usr/local/lib/node_modules/blynk-library/w1" in ["/root/.node_modules","/root/.node_libraries","/usr/local/lib/node"]
MODULE 1320: load "/usr/local/lib/node_modules/blynk-library/w1" for module "."
MODULE 1320: Module._load REQUEST /usr/local/lib/node_modules/w1temp parent: .
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp" in ["/usr/local/lib/node_modules/blynk-library/node_modules","/usr/local/lib/node_modules","/usr/local/node_modules","/usr/node_modules","/node_modules","/root/.node_modules","/root/.node_libraries","/usr/local/lib/node"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/index.js" for module "/usr/local/lib/node_modules/w1temp/dist/index.js"
MODULE 1320: Module._load REQUEST ./lib/setGpioPower parent: /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: RELATIVE: requested: ./lib/setGpioPower set ID to: /usr/local/lib/node_modules/w1temp/dist/index.js/lib/setGpioPower from /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp/dist/index.js/lib/setGpioPower" in ["/usr/local/lib/node_modules/w1temp/dist"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/lib/setGpioPower.js" for module "/usr/local/lib/node_modules/w1temp/dist/lib/setGpioPower.js"
MODULE 1320: Module._load REQUEST gpio parent: /usr/local/lib/node_modules/w1temp/dist/lib/setGpioPower.js
MODULE 1320: looking for "gpio" in ["/usr/local/lib/node_modules/w1temp/dist/lib/node_modules","/usr/local/lib/node_modules/w1temp/dist/node_modules","/usr/local/lib/node_modules/w1temp/node_modules","/usr/local/lib/node_modules","/usr/local/node_modules","/usr/node_modules","/node_modules","/root/.node_modules","/root/.node_libraries","/usr/local/lib/node"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/node_modules/gpio/lib/gpio.js" for module "/usr/local/lib/node_modules/w1temp/node_modules/gpio/lib/gpio.js"
MODULE 1320: Module._load REQUEST fs parent: /usr/local/lib/node_modules/w1temp/node_modules/gpio/lib/gpio.js
MODULE 1320: load native module fs
MODULE 1320: Module._load REQUEST util parent: /usr/local/lib/node_modules/w1temp/node_modules/gpio/lib/gpio.js
MODULE 1320: load native module util
MODULE 1320: Module._load REQUEST path parent: /usr/local/lib/node_modules/w1temp/node_modules/gpio/lib/gpio.js
MODULE 1320: load native module path
MODULE 1320: Module._load REQUEST events parent: /usr/local/lib/node_modules/w1temp/node_modules/gpio/lib/gpio.js
MODULE 1320: load native module events
MODULE 1320: Module._load REQUEST ./lib/setGpioData parent: /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: RELATIVE: requested: ./lib/setGpioData set ID to: /usr/local/lib/node_modules/w1temp/dist/index.js/lib/setGpioData from /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp/dist/index.js/lib/setGpioData" in ["/usr/local/lib/node_modules/w1temp/dist"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/lib/setGpioData.js" for module "/usr/local/lib/node_modules/w1temp/dist/lib/setGpioData.js"
MODULE 1320: Module._load REQUEST child_process parent: /usr/local/lib/node_modules/w1temp/dist/lib/setGpioData.js
MODULE 1320: load native module child_process
MODULE 1320: Module._load REQUEST ./lib/getSensorsUids parent: /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: RELATIVE: requested: ./lib/getSensorsUids set ID to: /usr/local/lib/node_modules/w1temp/dist/index.js/lib/getSensorsUids from /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp/dist/index.js/lib/getSensorsUids" in ["/usr/local/lib/node_modules/w1temp/dist"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/lib/getSensorsUids.js" for module "/usr/local/lib/node_modules/w1temp/dist/lib/getSensorsUids.js"
MODULE 1320: Module._load REQUEST fs parent: /usr/local/lib/node_modules/w1temp/dist/lib/getSensorsUids.js
MODULE 1320: Module._load REQUEST ./fileExistsWait parent: /usr/local/lib/node_modules/w1temp/dist/lib/getSensorsUids.js
MODULE 1320: RELATIVE: requested: ./fileExistsWait set ID to: /usr/local/lib/node_modules/w1temp/dist/lib/fileExistsWait from /usr/local/lib/node_modules/w1temp/dist/lib/getSensorsUids.js
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp/dist/lib/fileExistsWait" in ["/usr/local/lib/node_modules/w1temp/dist/lib"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/lib/fileExistsWait.js" for module "/usr/local/lib/node_modules/w1temp/dist/lib/fileExistsWait.js"
MODULE 1320: Module._load REQUEST fs parent: /usr/local/lib/node_modules/w1temp/dist/lib/fileExistsWait.js
MODULE 1320: Module._load REQUEST ./constants parent: /usr/local/lib/node_modules/w1temp/dist/lib/getSensorsUids.js
MODULE 1320: RELATIVE: requested: ./constants set ID to: /usr/local/lib/node_modules/w1temp/dist/lib/constants from /usr/local/lib/node_modules/w1temp/dist/lib/getSensorsUids.js
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp/dist/lib/constants" in ["/usr/local/lib/node_modules/w1temp/dist/lib"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/lib/constants.js" for module "/usr/local/lib/node_modules/w1temp/dist/lib/constants.js"
MODULE 1320: Module._load REQUEST ./lib/getSensor parent: /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: RELATIVE: requested: ./lib/getSensor set ID to: /usr/local/lib/node_modules/w1temp/dist/index.js/lib/getSensor from /usr/local/lib/node_modules/w1temp/dist/index.js
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp/dist/index.js/lib/getSensor" in ["/usr/local/lib/node_modules/w1temp/dist"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js" for module "/usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js"
MODULE 1320: Module._load REQUEST ./fileExistsWait parent: /usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js
MODULE 1320: RELATIVE: requested: ./fileExistsWait set ID to: /usr/local/lib/node_modules/w1temp/dist/lib/fileExistsWait from /usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js
MODULE 1320: Module._load REQUEST ./Sensor parent: /usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js
MODULE 1320: RELATIVE: requested: ./Sensor set ID to: /usr/local/lib/node_modules/w1temp/dist/lib/Sensor from /usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js
MODULE 1320: looking for "/usr/local/lib/node_modules/w1temp/dist/lib/Sensor" in ["/usr/local/lib/node_modules/w1temp/dist/lib"]
MODULE 1320: load "/usr/local/lib/node_modules/w1temp/dist/lib/Sensor.js" for module "/usr/local/lib/node_modules/w1temp/dist/lib/Sensor.js"
MODULE 1320: Module._load REQUEST fs parent: /usr/local/lib/node_modules/w1temp/dist/lib/Sensor.js
MODULE 1320: Module._load REQUEST events parent: /usr/local/lib/node_modules/w1temp/dist/lib/Sensor.js
MODULE 1320: Module._load REQUEST ./constants parent: /usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js
MODULE 1320: RELATIVE: requested: ./constants set ID to: /usr/local/lib/node_modules/w1temp/dist/lib/constants from /usr/local/lib/node_modules/w1temp/dist/lib/getSensor.js
[ '00-746000000000', '00-f46000000000' ]
(node:1320) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Cant get sensor instance
Can´t remember if I did it with sudo, I think i used it, since without it an error showing that the installation had no access to certain paths of the system was displayed.
@raul after much trial and error I can get exactly the same error message as you:
MODULE 3586: looking for "/opt/nodejs/bin/node_modules/w1temp/dist/lib/constants" in ["/opt/nodejs/bin/node_modules/w1temp/dist/lib"]
[ '00-200000000000' ]
(node:3586) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Cant get sensor instance
dmesg is quite useful with these sensors, call the command after each failed attempt and you should see something like this:
[50718.941986] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
[50780.753439] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
[50828.393643] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
Having worked so hard to duplicate your error message it has messed up my system a little. All still working but now the search ID has one correct entry and a rogue ghost entry: [ '00-100000000000', '28-0004412479ff' ]
OK so how did I get your error message. I simply pulled out the sensor from the breadboard. Strangely at first it still made reference to the correct ID and a temperature of 0 degrees. After a few more attempts the ghost ID’s appeared and finally “Can’t get sensor instance”.
I have a version 2 script for you to try, called w1v2.js, just a couple of lines:
var W1Temp = require('/opt/nodejs/bin/node_modules/w1temp');
W1Temp.getSensorsUids().then(function (sensorsUids) {
console.log(sensorsUids);
As you know this just looks for the ID. You need to check and double check the sensor circuit. I mainly use the plug and play sensors but you should try with both versions. I am a little surprised that the system works at all without any pin definitions but I have a clue.
I don’t currently have any entries in the config.txt file on the SD card and no modprobe in crontab or elsewhere. But maybe when I first set it all up I did have the SD card entry (GPIO / BCM 7) and when I did the one off modprobe the pin is permanently registered unless you remove it from the OS.
So that’s certainly worth a try as per the docs, but ensure you use 7 if the sensor is wired up to 7.
Wow man, awesome work! I will check this as soon as I eat something, will replay with conclusions ASAP.
I really appreciate your help, you are being amazingly helpful and supportive.
Thanks!!!
[ 59.339371] w1_master_driver w1_bus_master1: Family 0 for 00.800000000000.8c is not registered.
[ 118.956403] w1_master_driver w1_bus_master1: Family 0 for 00.400000000000.46 is not registered.
[ 166.697502] w1_master_driver w1_bus_master1: Family 0 for 00.c00000000000.ca is not registered.
[ 237.990070] w1_master_driver w1_bus_master1: Family 0 for 00.200000000000.23 is not registered.
[ 297.331802] w1_master_driver w1_bus_master1: Family 0 for 00.a00000000000.af is not registered.
[ 332.744244] w1_master_driver w1_bus_master1: Family 0 for 00.600000000000.65 is not registered.
[ 370.083917] w1_master_driver w1_bus_master1: Family 0 for 00.e00000000000.e9 is not registered.
[ 428.945608] w1_master_driver w1_bus_master1: Family 0 for 00.100000000000.9d is not registered.
[ 465.257615] w1_master_driver w1_bus_master1: Family 0 for 00.900000000000.11 is not registered.
[ 535.618923] w1_master_driver w1_bus_master1: Family 0 for 00.500000000000.db is not registered.
[ 583.880575] w1_master_driver w1_bus_master1: Family 0 for 00.d00000000000.57 is not registered.
[ 608.361038] w1_master_driver w1_bus_master1: Family 0 for 00.300000000000.be is not registered.
[ 654.703589] w1_master_driver w1_bus_master1: Family 0 for 00.b00000000000.32 is not registered.
[ 691.133758] w1_master_driver w1_bus_master1: Family 0 for 00.700000000000.f8 is not registered.
[ 739.404933] w1_master_driver w1_bus_master1: Family 0 for 00.f00000000000.74 is not registered.
[ 797.878119] w1_master_driver w1_bus_master1: Family 0 for 00.080000000000.c2 is not registered.
[ 847.098407] w1_master_driver w1_bus_master1: Family 0 for 00.880000000000.4e is not registered.
[ 882.449605] w1_master_driver w1_bus_master1: Family 0 for 00.480000000000.84 is not registered.
[ 929.751004] w1_master_driver w1_bus_master1: Family 0 for 00.c80000000000.08 is not registered.
[ 1001.192726] w1_master_driver w1_bus_master1: Family 0 for 00.280000000000.e1 is not registered.
[ 1060.444223] w1_master_driver w1_bus_master1: Family 0 for 00.a80000000000.6d is not registered.
[ 1119.697256] w1_master_driver w1_bus_master1: Family 0 for 00.680000000000.a7 is not registered.
[ 1156.966841] w1_master_driver w1_bus_master1: Family 0 for 00.e80000000000.2b is not registered.
[ 1215.948267] w1_master_driver w1_bus_master1: Family 0 for 00.180000000000.5f is not registered.
[ 1252.318785] w1_master_driver w1_bus_master1: Family 0 for 00.980000000000.d3 is not registered.
[ 1298.601538] w1_master_driver w1_bus_master1: Family 0 for 00.580000000000.19 is not registered.
[ 1346.930554] w1_master_driver w1_bus_master1: Family 0 for 00.d80000000000.95 is not registered.
[ 1371.470737] w1_master_driver w1_bus_master1: Family 0 for 00.380000000000.7c is not registered.
[ 1417.872318] w1_master_driver w1_bus_master1: Family 0 for 00.b80000000000.f0 is not registered.
[ 1478.021901] w1_master_driver w1_bus_master1: Family 0 for 00.780000000000.3a is not registered.
[ 1526.342894] w1_master_driver w1_bus_master1: Family 0 for 00.f80000000000.b6 is not registered.
[ 1584.933597] w1_master_driver w1_bus_master1: Family 0 for 00.040000000000.61 is not registered.
[ 1634.214661] w1_master_driver w1_bus_master1: Family 0 for 00.840000000000.ed is not registered.
[ 1693.406111] w1_master_driver w1_bus_master1: Family 0 for 00.440000000000.27 is not registered.
[ 1740.767056] w1_master_driver w1_bus_master1: Family 0 for 00.c40000000000.ab is not registered.
[ 1764.108157] w1_master_driver w1_bus_master1: Family 0 for 00.240000000000.42 is not registered.
[ 1823.419051] w1_master_driver w1_bus_master1: Family 0 for 00.a40000000000.ce is not registered.
[ 1848.679541] w1_master_driver w1_bus_master1: Family 0 for 00.640000000000.04 is not registered.
[ 1896.041099] w1_master_driver w1_bus_master1: Family 0 for 00.e40000000000.88 is not registered.
[ 1955.261941] w1_master_driver w1_bus_master1: Family 0 for 00.140000000000.fc is not registered.
[ 1991.573103] w1_master_driver w1_bus_master1: Family 0 for 00.940000000000.70 is not registered.
[ 2061.814526] w1_master_driver w1_bus_master1: Family 0 for 00.540000000000.ba is not registered.
[ 2110.074921] w1_master_driver w1_bus_master1: Family 0 for 00.d40000000000.36 is not registered.
[ 2182.236275] w1_master_driver w1_bus_master1: Family 0 for 00.340000000000.df is not registered.
[ 2228.577903] w1_master_driver w1_bus_master1: Family 0 for 00.b40000000000.53 is not registered.
[ 2264.887544] w1_master_driver w1_bus_master1: Family 0 for 00.740000000000.99 is not registered.
[ 2313.148434] w1_master_driver w1_bus_master1: Family 0 for 00.f40000000000.15 is not registered.
[ 2371.859774] w1_master_driver w1_bus_master1: Family 0 for 00.0c0000000000.a3 is not registered.
[ 2421.080550] w1_master_driver w1_bus_master1: Family 0 for 00.8c0000000000.2f is not registered.
[ 2456.553704] w1_master_driver w1_bus_master1: Family 0 for 00.4c0000000000.e5 is not registered.
[ 2503.853370] w1_master_driver w1_bus_master1: Family 0 for 00.cc0000000000.69 is not registered.
[ 2527.133863] w1_master_driver w1_bus_master1: Family 0 for 00.2c0000000000.80 is not registered.
[ 2586.386652] w1_master_driver w1_bus_master1: Family 0 for 00.ac0000000000.0c is not registered.
[ 2635.727886] w1_master_driver w1_bus_master1: Family 0 for 00.6c0000000000.c6 is not registered.
[ 2683.029767] w1_master_driver w1_bus_master1: Family 0 for 00.ec0000000000.4a is not registered.
[ 2742.142123] w1_master_driver w1_bus_master1: Family 0 for 00.1c0000000000.3e is not registered.
[ 2778.523507] w1_master_driver w1_bus_master1: Family 0 for 00.9c0000000000.b2 is not registered.
[ 2824.925194] w1_master_driver w1_bus_master1: Family 0 for 00.5c0000000000.78 is not
I changed my sensor to gpio 4, but the same error in dmsg appears…
