Crazy man, now the led is blinking, which means: yes it works, but what more?
Now I tried both version: First with the pin declaration 2 and after with D4. By both versions the led blinks
Both versions will work with Blynk, but it’s not good programming practice to use the D numbers rather that GPIO numbers because it makes it much more difficult to transfer yoir code from one device to another.
The D references won’t work with an Arduino, or possibly with future boards, whereas directly referencing the GPIO pins will work on any platform.
@PeteKnight After a year+ of hearing someone gripe about “stupid silk screening” I find out that it was intentional on Wemo’s part… probably part of their D1 board nomenclature.
Now that I know, I actually use the Dpin labeling for Wemos code. I think it is a good idea since I constantly use both types of boards, and now know at a glance if my sketch pin-outs are correct, instead of always dragging out my little black binder of board pin-outs
Foolish, why didn’t they just put the correct GPIO numbers.
Even though D references work when compiling as WeMos that doesn’t really fix the issue.
You need the real GPIO’s when you start using Blynk’s API etc and when you compile as a generic ESP8266 for the additional debugging.
I would still well clear of the WeMos and NodeMCU labelling of pins.
Yes, but I also still use Arduino and ESP-01… born to be a lone wolf I guess :
@Hannes.P Sorry, this side discussion is probably best in that other semi related topic. Meanwhile, stick with proper Arduino pin designation and let us know if you got your code working with pinMode()
Yeah men, thanks! You are the best!
First step, switch on an off a LED works now, lets go on, there is still much more potential in Blynk.
If someone need in future a sketch to switch something which is hardware interrupt with a microcotroller, here is a sketch which works (used with a Wemos D1 mini):
char auth[] = "b5a2426a237549448f9dff83xxxxxxxx"
char ssid[] = "Fritzboxxxxx";
char pass[] = "xxxx37094862xxxxxxxx";
BLYNK_WRITE(V1)
if (pinValue == 1) { // If value is 1 run this command
digitalWrite(D4, HIGH); //D4 output from Wemos D1 mini
else { // If value is 0 run this command
digitalWrite(D4, LOW);
Serial.print("V1 Button value is: ");
Serial.println(pinValue);
pinMode(D4, OUTPUT);
Hi guys I would need again help from you
Also now I wrote a lot of codes, as much that I can no longer lost my view
Joke not really, but I had a question to a simple sequence. To understand better I copy below an extract from my sketch. Also I would realize a central function which means in my case:
Only if button V3 is pressed, the action from slider V4 can start, which means only when button V3 is pressed, I am able to dim an led which is conected on D3. Only dimming a led without any condition (in my case if pinValue == 1 in row 28) works but I would like to add it in my sketch
Thanks in the meantime
char auth[] = "b5a2426a237549448f9dff83a354xxxx";
char pass[] = "67033709486218110xxxx";
int pinValue = 0; //status from Button V1
int brightness = 0; //value from Slider V3
BLYNK_WRITE(V1)
int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable (Button)
digitalWrite(D4, HIGH); // D1 output from Wemos D1 mini
digitalWrite(D4, LOW); // D1 output from Wemos D1 mini
Serial.print("V1 Button value is: "); // Output the value "pinValue" in Serial Monitor
BLYNK_WRITE(V3)
int brightness = param.asInt(); // assigning incoming value from pin V3 to a variable
if (pinValue == 1){
analogWrite (D3, brightness); // D3 output from Wemos D1 mini
Serial.print("V1 Slider value is: "); // Output the value "brightness" in Serial Monitor
Serial.println(brightness);
pinMode(D4, OUTPUT); // D4 is an output (digital)
pinMode(D3, OUTPUT); // D3 is an output (analog)
You 2nd to last post (above) was basically about same general issue as this whole topic… but posted in a new topic. But having multiple topics on same issue is not really allowed, so I merged your last post back into this original topic… hope this clears that up
Hey Gunner,
recently I really would not spam, it was only a wrong click because of my gaucherie Hope you can forgive me
No about me problem with the understanding from Blynk… now I would program something which works like a lock, which means, only when something is happen, the other thing can work. I would use this for a central off funciton of the final sketch. Now I wrote this sketch, where led on D4 lights, when button V1 is pressed and led on D1 should light only if button V1 and V7 is pressed. I just can not find my error… To test I use only digitaloutputs so I wrote digitalWrite(D1, HIGH). The declaration with the output Pins from the wemos we clarified just last one, also that I have to declare the outputPin in void setup() as an output… I did all. If I let away the condition that D1 lights only when button v1 is also pressedork i can control both leds with to different buttons but is not what I want. Thereby I can also exclude an error by wiring. Here the sketch
char pass[] = "6703370948621811xxxx";
int StatusV1 = 0; //status from Button V1
int StatusV7 = 0; //value from Slider V3
BLYNK_WRITE(V1)
int StatusV1 = param.asInt(); // assigning incoming value from pin V1 to a variable (Button)
if (StatusV1 == 1) { // If value is 1 run this command
Serial.print("StatusV1 is: "); // Output the value "pinValue" in Serial Monitor
Serial.println(StatusV1);
BLYNK_WRITE(V7)
int StatusV7 = param.asInt(); // assigning incoming value from pin V1 to a variable (Button)
if ((StatusV7 == 1) && (StatusV1 == 1)) // If value is 1 run this command
digitalWrite(D1, HIGH); // D1 output from Wemos D1 mini
digitalWrite(D1, LOW); // D1 output from Wemos D1 mini
Serial.print("StatusV7 is: "); // Output the value "pinValue" in Serial Monitor
Serial.println(StatusV7);
pinMode(D1, OUTPUT); // D1 is an output (digital)
Could it be problem from the declartion from the variable “StatusV1”? Can I use it only in the function from BLYNK_WRITE(V1) or it´s possible to declare it as an global variable how I did it at the begin from the sketch?
But this work:
int StatusV7 = 0; //status from Button V7
BLYNK_WRITE(V1)
int StatusV1= param.asInt(); // assigning incoming value from pin V1 to a variable (Button)
BLYNK_WRITE(V7)
if (StatusV7 == 1) // If value is 1 run this command
Here I control both LED with two different buttons, but without any condition between the lights (not what I want but hope you can help me )
Try this… it is something like what I will be adding soon to my Code Collection Topic
Each button press (or release) triggers it’s Function and sets the sate of it’s button.
That Function will check if both button states are HIGH, and if so, turns on the LED
But if one state is LOW then it turns OFF the LED and calls the other Function, which repeats the check.
Thus, regardless of which button gets called pressed first, nothing happens until the second on is also pressed.
This will work with buttons in “button” or “switch” mode for different conditions (e.g. both must be pressed down to activate, one or the other can be a safety switch for the other momentary button, or both can be safety switches)
int Button1, Button2, DevLED=D4; // D4 can also be indicated as pin 2)
BLYNK_WRITE(V1) { // Button 1
Button1 = param.asInt(); // Get value as integer
if (Button1 && Button2 == 1) {
digitalWrite(DevLED, HIGH); // If both buttons ON, turn on LED...
digitalWrite(DevLED, LOW); // ...else turn OFF LED
Blynk.syncVirtual(V7); // Check button 2
BLYNK_WRITE(V7) { // Button 2
Button2 = param.asInt(); // Get value as integer
Blynk.syncVirtual(V1); // Check button 1
Hi Gunnar, sorry to disturb you again, but trying to make my code more flexible and to avoid the row
I think, I have found an other solution which should (with accent to should) work. The reality says something other… sadly
Once I learnt something about counters and flags, so I thought it should works also with Blynk. For the reason that I do not like switches (because usually I forget to switch them off afer I switched them on) I want write something which works like an impulse. When I push a Button the first time it sets a flag HIGH with the second push again LOW). So I could avoid usually the row when I write more functions where I have to request the status from the flag “varCentralOut”.
char auth[] = "aace274ad74842ea93387312b6xxxxx";
char ssid[] = "Fritzbox3272";
char pass[] = "xxxxxxxxxxxxxxxxxx";
int varCentralOut = 0; //flag central Out
int varMode1 = 0; //flag Modue 1
int varMode2 = 0; //flag Modue 2
int varMode3 = 0; //flag Modue 3
int varMode4 = 0; //flag Modue 4
int varLedOutput = 0; //flag to simulate output signal
int LedPin = D3; //LED conected to D3
pinMode (D3, OUTPUT); //Pin D3 is an output Pin
BLYNK_WRITE(V20) //Function Central Out
int CentralOut = param.asInt(); //Get value from Button V20
if (CentralOut == 1) { //if it is HIGH
varCentralOut++; //count the flag "varCentralOut" ++
if (varCentralOut == 2) { //if the Button get pushed a second one
varCentralOut = 0; //flag "varCentralOut" is again 0
Serial.print ("CentralOut is "); //Output the text "CentralOut is " in Serial Monitor
Serial.println (CentralOut); //Output the status from Button V20 in Serial Monitor
Serial.print ("varCentralOut is "); //Output the text "varCentralOut" in Serial Monitor
Serial.println (varCentralOut); //Output the flag "varCentralOut" in Serial Monitor
BLYNK_WRITE(V21) //Function Mode 1
int Mode1 = param.asInt(); //Get value from Button V21
if (Mode1 == 1) { //if it is HIGH
varMode1++; //count the flag "varMode1" ++
if (Mode1 == 2) { //if the Button get pushed a second one
varMode1= 0; //flag "varCentralOut" is again 0
if ((varMode1 == 1) && (varCentralOut == 0)) {
(varLedOutput = 1);
digitalWrite (LedPin, HIGH);
Serial.print ("Mode1 is "); //Output the text "CentralOut is " in Serial Monitor
Serial.println (Mode1); //Output the status from Button V21 in Serial Monitor
Serial.print ("varMode1 is "); //Output the text "varMode1 is " in Serial Monitor
Serial.println (varMode1); //Output the flag "varMode1" in Serial Monitor
Serial.print ("varLedOutput is ") //Output the text "varLedOutput" in Serial Monitor
Serial.println (varLedOutput); //Output the flag "varLedOutput" in Serial Monitor
......Mode 2 how Mode 1 (Button V22)
......Mode 3 how Mode 1 (Button V23)
......Mode 3 how Mode 1 (Button V24)
To explain you how it should work: There are four differnt modes which all became started/switched on by pushing them different button. When I push the central off button, all flags become reseted and everything become switch off. I do not know why but I get the real values in Serial Monitor when I press the buttons.
I see for example that varMode1 == 1 and that varCentralOut == 1 but varLedOutput change never his value from 0 to 1, so I think there must be the error. Where I could than write the condition, because
if ((varMode1 == 1) && (varCentralOut == 1)) {
varLedOutput = 1;
So… I arrived at the end from my sermon. You know on? Where is the error of my thinking hidden?
Would be very nice if (you could help me == 1) {
thanks in the meantime; }
else {frack you;}
No, joke, you are the best
Yeah, I am the hero of the loops
Hi guys,
hope you can help me on, Gunnar could not, so I decided to ask the whole community.
Hope it´s okay (But he remains again usually the best ) Not let`s come to my question. It is a simply thinking but it does not work how I want.
How is it possible to compare flags. Also, I would like that I push a button in Blynk App, which is set to PUSH, after I set a flag HIGH. With the next push on the same button, the flag gets reseted to LOW. So far so good, it works until there.
Now I want have more different buttons which works all like this.
So I think, I can write a more flexible sketch. The main reason I need to realize a central out function. With one click I want switch down all functions with works at the same time. To explain you. I have a sketch with more modes. All I switch from the App with seperate buttons. If I click then at the central out button, all should go off.
Here a part of the sketch:
(varLedOutput = 1);
…Mode 2 how Mode 1 (Button V22)
…Mode 3 how Mode 1 (Button V23)
…Mode 3 how Mode 1 (Button V24)
In Serial Monitor I see that the flags get set, only the flag “varLedOutput” does not work. There must be somethink wrong with the line, where I ask the programm if ((varMode1 == 1) && (varCentralOut == 0)).
varLedOutput gets never 1.
Hope you understood my “problem” and there is someone who can help me on
This topic is still visible to the “whole forum” so no need to create a new topic. I merged it back
PS, if others do NOT intervene, that means they are either not around, do not want to troubleshoot your code (as it is not really a Blynk related issue) or they can’t… there is no benefit to repeated requests. You could Google around for other related tutorials on how boolean comparators and flags work
Thank you… I try, but am not omniscient… or often awake enough to think clearly
The variable varCentralOut isn’t declared in the code that you’ve shared here. It must be declared somewhere, otherwise your code wouldn’t compile, so there must be more code that you’ve not shared.
That makes it difficult for people to work-out what’s going wrong with your code/logic. Try sharing your whole sketch.
