Hi all blynk-er.
I’m a newbie.
I’m having trouble with source code. Can I get advice from you?
I came to Blynk in 3 days. I just want to say that this is a great thing. It is a pity to know Blynk too late.
I am building an automatic water pump system. I want to add a flow switch, when the water system is out of pause and the error light is on. When the water level drops below 30, relay works. NodeMCU will wait for 20 seconds. If the flow switch is activated (NO), relay will remain active. And if the flow switch is open (NC) , the system will report an error and send a notification via the Blynk application.
When the well is out of water, the water switch is open, the system is in standby mode, only kích hoạt khi bấm nút trên Blynk application. The click button resets the state to its original state.
It’s too complicated for a newbie.
Hope this theme will inspire others.
//#include <ArduinoOTA.h>
#include <Wire.h>
//#include "DHT.h"
#include "Settings.h"
/* Blynk */
WidgetLCD lcd(V0);
WidgetLCD status(V1);
//#define dhtPin 12
//#define DHTTYPE DHT11
#define echoPin 13 // Echo Pin
#define trigPin 15 // Trigger Pin
#define pumpPin 5 // Relay
#define pumpButton 4
long duration, distance; // Duration used to calculate distance
// PINMODES
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(pumpPin, OUTPUT);
pinMode(pumpButton, INPUT_PULLUP);
// COMMUNICATIONS
WiFi.mode(WIFI_STA);
// CONNECT TO BLYNK
#ifdef LOCAL_SERVER
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, LOCAL_SERVER);
#else
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS);
#endif
while (Blynk.connect() == false) {}
Blynk.syncVirtual(vPIN_LIMITMENU, vPIN_WATER_COST, vPIN_WATER_TOTAL_MONTH, vPIN_RESSET);
// OVER THE AIR UPDATES
//ArduinoOTA.setHostname(OTA_HOSTNAME);
//ArduinoOTA.begin();
timer.setInterval(1000, MeasureCm);
BLYNK_READ(V8)
Blynk.virtualWrite(8,distance);// virtualpin 8
BLYNK_READ(V7)
Blynk.virtualWrite(7,duration);// virtualpin 8
* Calculation of ultrasonic sensor and relay control :
void MeasureCm()
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
Serial.print("Distance :" + distance);
Serial.println(distance);
lcd.clear();
// thiet lap muc nuoc su dung xuong 30 cm thi tu dong bat relay
if (distance >= 30 ){
Blynk.notify("GioLangLe-IoT : He thong bom nuoc da duoc khoi dong!");
digitalWrite (pumpPin, LOW);
Serial.print("Relay On");
// thiet lap muc nuoc len den 10 cm thi tu dong tat relay
if (distance < 10 ){
Blynk.notify("GioLangLe-IoT : Nuoc da day, he thong tro ve trang thai cho...");
digitalWrite (pumpPin, HIGH);
Serial.print("Relay Off ");
And Settings.h
#define AUTH "xxxx"
#define WIFI_SSID "xxxx"
#define WIFI_PASS "xxxx"
//#define OTA_HOSTNAME "GIOLANGLE-IOT"
//#define LOCAL_SERVER IPAddress(192, 168, 1, 22)
I am trying… i using base ArduFarmBot2
The compilation happens without error … But it still does not work. Functions do not work.
Main
#include <Wire.h>
#include "Defines.h"
/* Blynk */
WidgetLCD lcd(V0);
WidgetLED PUMPs(V0); // Echo signal to Sensors Tab at Blynk App
WidgetLED PUMPa(V1); // Echo signal to Actuators Tab at Blynk App
WidgetLED LAMPs(V1); // Echo signal to Sensors Tab at Blynk App
WidgetLED LAMPa(V6); // Echo signal to Actuators Tab at Blynk App
/* DHT11 */
#include "DHT.h"
DHT dht(DHTPIN, DHTTYPE);
/* TIMER */
/* UltraSonic */
int maximumRange = 150;
// int distance;
// PINMODES
//pinMode(lampPin, INPUT_PULLUP);
// COMMUNICATIONS
// CONNECT TO BLYNK
#ifdef LOCAL_SERVER
#else
#endif
dht.begin();
PUMPs.off();
PUMPa.off();
LAMPa.off();
digitalWrite(pumpPin, HIGH); // To be used with Relay module (inverted logic: normally HIGH)
digitalWrite(lampPin, HIGH); // To be used with Relay module (inverted logic: normally HIGH)
* Read remote commands
BLYNK_WRITE(3) // Pump remote control
int i=param.asInt();
if (i==1)
pumpStatus = !pumpStatus;
aplyCmd();
BLYNK_WRITE(4) // Lamp remote control
if (i==1)
lampStatus = !lampStatus;
aplyCmd();
* Read local commands Flow swich (NO)and Lamp buttons are normally "HIGH":
void readLocalCmd()
boolean digiValue = debounce(pumpButton);
if (!digiValue)
aplyCmd();
* Receive Commands and act on RELAYs - Logic LOW
void aplyCmd()
if (pumpStatus == 1)
Blynk.notify("Pump System: Warning ==>> Pump ON");
digitalWrite(pumpPin, LOW); // To be used with Relay module (inverted logic: activate with LOW)
PUMPs.on();
PUMPa.on();
PUMPs.off();
PUMPa.off();
if (lampStatus == 1)
Blynk.notify("Factory : Warning ==>> Lamp ON");
digitalWrite(lampPin, LOW); // To be used with Relay module (inverted logic: activate with LOW)
LAMPs.on();
LAMPa.on();
LAMPs.off();
LAMPa.off();
status.clear();
status.print(0,0,"Motor Online");
status.clear();
status.print(0,0,"Motor Offline");
* Turn Pump On for a certain amount of time
void turnPumpOn()
pumpStatus = 1;
aplyCmd();
delay (TIME_PUMP_ON*1000);
pumpStatus = 0;
aplyCmd();
* Turn Lamp On for a certain amount of time
void turnLampOn()
lampStatus = 1;
aplyCmd();
delay (TIME_LAMP_ON*1000);
lampStatus = 0;
aplyCmd();
* Send data to Blynk
void sendUptime()
Blynk.virtualWrite(10, airTemp); //virtual pin V10
Blynk.virtualWrite(11, airHum); // virtual pin V11
`**Defines.h**`
/* Automatic Control Parameters Definition */
#define HOT_TEMP 22
#define TIME_PUMP_ON 15
#define TIME_LAMP_ON 15
/* TIMER */
#define READ_BUTTONS_TM 1L // definitions in seconds
#define READ_AIR_DATA_TM 2L
#define SEND_UP_DATA_TM 10L
/* DHT11*/
#define DHTPIN 4
float airHum = 0;
float airTemp = 0;
/* Ultrasonic */
/* Relays */
#define lampPin 16 // Lamp Pin
boolean pumpStatus = 0;
boolean lampStatus = 0;
/* Buttons */
#define pumpButton 2 // Flow Swich
/* VPIN */
#define vPIN_WATER_TOTAL_MONTH V21
#define vPIN_WATER_COST V22
#define vPIN_LIMITMENU V23
#define vPIN_RESSET V24
Functions.ino
* Wait Button to be pressed a defined time in seconds
void waitButtonPress (int waitTime)
long startTiming = millis();
while (debounce(pumpButton))
if ((millis()-startTiming) > (waitTime*1000)) break;
* Starting Timers
void startTimers(void)
timer.setInterval(READ_BUTTONS_TM*1000, readLocalCmd);
timer.setInterval(READ_AIR_DATA_TM*1000, getDhtData);
timer.setInterval(SEND_UP_DATA_TM*1000, sendUptime);
* Debouncing a key
boolean debounce(int pin)
boolean state;
boolean previousState;
const int debounceDelay = 30;
previousState = digitalRead(pin);
for(int counter=0; counter< debounceDelay; counter++)
delay(1);
state = digitalRead(pin);
if(state != previousState)
counter = 0;
previousState = state;
return state;
Sensor.ino
* Get DHT data
void getDhtData(void)
float tempIni = airTemp;
float humIni = airHum;
airTemp = dht.readTemperature();
airHum = dht.readHumidity();
if (isnan(airHum) || isnan(airTemp)) // Check if any reads failed and exit early (to try again).
airTemp = tempIni;
airHum = humIni;
* Get Ultrasonic Sensor data
void MeasureCm()
I had to edit your post to correctly format your code for proper forum viewing, as documented in the Welcome Topic.
Hey, welcome to Blynk Community.
This is the best place to ask questions, leave feedback and share your ideas.
If this is the first time you hear about Blynk, check out our website www.blynk.cc and come back!
As the community is big (and growing), let’s agree on some basic rules.
Asking for help
Before creating a new topic and asking for help, please check if your question was already answered:
Use forum search function
You may want to check out:
Blynk Documentation
Blynk Wiki
Blynk Exa…
