Automatic scheduler. ESP-01 with 4 Time Input Widgets
Hi Blynkers,
Today I wanted to show you my last Project using Time_Input Widget as main character using the “simple” ESP-01.
This project starts using @Costas’ code, so, thanks as always, you are doing really good stuff!! :+1:
The little board:
The program goes like this:
As you can see, there’re 4 modes to be selected:
-Monday-Friday (Time-Input Pre-programmed from Monday to Friday)
-Saturday-Sunday (Time-Input Pre-programmed from Saturday to Sunday)
-All days (Time-Input Pre-programmed to run every single day)
-Up to you (you choose the days you want to turn on/off, at least one day must be selected!)
For example, If the button “All days” is pressed (like the picture) the Lamp (in my case) will Start at 14:05 and will Stop at 23:45 every single day.
When a new mode is pressed the program removes the other ones automatically (except Monday-Friday and Saturday-Sunday that can be used together).
You can always press “ON/OFF” button and the Manual mode will be activated. After that, if you press “Manual/Auto” to come back to the automatic program and the “old” state come back.
Every time a new mode is pressed, the device goes down waiting for new update. A new update occurs every 5 seconds for the video but 1 minute is fine, there’s no need to do it so fast)
Please, see the video for better understanding.
You can see below the unprofessional code, I have been adding and removing stuff till obtain something that works (at least till now…:slight_smile:)
Hope you like it.
And… yes, I’m running my own Local Server @Dmitriy :wink:, there’re NO Delays!
The code is below:
 * timeinput.ino Demonstrate interaction of Time library with
 * Blynk's TimeInput widget.
 * App project setup:
 * RTC widget (no pin required!!!)
 * V1 : Manual/Auto button
 * V2: On-off button
 * Terminal on V3 // Label will be the clock + wifi signal!!!!
 * Time Input widget on V4 (Monday-Friday)
 * Button selection for Time Input (Monday-Friday) on V5
 * Time Input widget on V6 (Saturday-Sunday)
 * Button selection for Time Input (Saturday-Sunday on V7
 * Time Input widget on V8 (All days)
 * Button selection for Time Input (All days) on V9
 * Time Input widget on V10 (Up to you)
 * Button selection for Time Input (Up to you) on V11
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
WidgetTerminal terminal(V3);
#define server "XXX.XXX.XXX.XXX"   // or "blynk.cloud-com" for Blynk's cloud server
#define TestLED 2                 // on board LED pin assignment
char Date[16];
char Time[16];
char auth[] = "XXXXXXXXXXXXXXXXXXXXXXX";
char ssid[] = "XXXXXXX";
char pass[] = "XXXXXXXXXXXXXX";
long startsecondswd;            // weekday start time in seconds
long stopsecondswd;             // weekday stop  time in seconds
long nowseconds;                // time now in seconds
bool isFirstConnect = true;
String displaycurrenttimepluswifi;
int wifisignal;
int manual=0;
int oldstatus;
int mondayfriday;
int saturdaysunday;
int alldays;
int uptoyou;
  pinMode(TestLED, OUTPUT);
  digitalWrite(TestLED, LOW); // set LED OFF
  Serial.println("\Starting");
  Blynk.begin(auth, ssid, pass, server);
  int mytimeout = millis() / 1000;
  while (Blynk.connect() == false) { // try to connect to server for 10 seconds
    if((millis() / 1000) > mytimeout + 8){ // try local server if not connected within 9 seconds
       break;
  rtc.begin();
  timer.setInterval(10000L, activetoday);  // check every 10 SECONDS if schedule should run today
  timer.setInterval(30000L, reconnectBlynk);  // check every 30s if still connected to server
  timer.setInterval(5000L, clockvalue);  // check value for time
  timer.setInterval(5000L, sendWifi);    // Wi-Fi singal
BLYNK_CONNECTED() {
if (isFirstConnect) {
  Blynk.syncAll();
  Blynk.notify("TIMER STARTING!!!!");
isFirstConnect = false;
void sendWifi() {
  wifisignal = map(WiFi.RSSI(), -105, -40, 0, 100);
void clockvalue() // Digital clock display of the time
 int gmthour = hour();
  if (gmthour == 24){
     gmthour = 0;
  String displayhour =   String(gmthour, DEC);
  int hourdigits = displayhour.length();
  if(hourdigits == 1){
    displayhour = "0" + displayhour;
  String displayminute = String(minute(), DEC);
  int minutedigits = displayminute.length();
  if(minutedigits == 1){
    displayminute = "0" + displayminute;
  displaycurrenttimepluswifi = "                                          Clock:  " + displayhour + ":" + displayminute + "               Signal:  " + wifisignal +" %";
  Blynk.setProperty(V3, "label", displaycurrenttimepluswifi);
void activetoday(){        // check if schedule should run today
  if(year() != 1970){
   if (mondayfriday==1) {
    Blynk.syncVirtual(V4); // sync timeinput widget
   if (saturdaysunday==1) {
    Blynk.syncVirtual(V6); // sync timeinput widget
   if (alldays==1) {
    Blynk.syncVirtual(V8); // sync timeinput widget
   if (uptoyou==1) {
    Blynk.syncVirtual(V10); // sync timeinput widget
void checklastbuttonpressed (){
    if((mondayfriday==1)&&(saturdaysunday==0)){ oldstatus=1; }
    if((mondayfriday==0)&&(saturdaysunday==1)){ oldstatus=2; }
    if((mondayfriday==1)&&(saturdaysunday==1)){ oldstatus=3; }
    if(alldays==1){ oldstatus=4; }
    if(uptoyou==1){ oldstatus=5; }
    if((mondayfriday==0)&&(saturdaysunday==0)&&(alldays==0)&&(uptoyou==0)){ oldstatus=6; }
void restorelastbuttonpressed (){
    if(oldstatus==1){ mondayfriday=1; Blynk.virtualWrite(V5, 1); }
    if(oldstatus==2){ saturdaysunday=1 ; Blynk.virtualWrite(V7, 1); }
    if(oldstatus==3){ saturdaysunday=1; mondayfriday=1;Blynk.virtualWrite(V5, 1);Blynk.virtualWrite(V7, 1); }
    if(oldstatus==4){ alldays=1; Blynk.virtualWrite(V9, 1);}
    if(oldstatus==5){ uptoyou=1; Blynk.virtualWrite(V11, 1);}
    if(oldstatus==6){
      mondayfriday=0;
      saturdaysunday=0;
      alldays=0;
      uptoyou=0;
      Blynk.virtualWrite(V5, 0);
      Blynk.virtualWrite(V7, 0);
      Blynk.virtualWrite(V9, 0);
      Blynk.virtualWrite(V11, 0);
BLYNK_WRITE(V1)  // Manual/Auto selection
  if (param.asInt()==1) {
    manual=1;
    terminal.println();
    terminal.println();
    terminal.println();
    terminal.println("Manual MODE is ON");
    terminal.println("Press ON/OFF button if required");
    terminal.println();
    terminal.println();
    terminal.println();
    terminal.flush();
    checklastbuttonpressed ();
    alldays=0;
    uptoyou=0;
    mondayfriday=0;
    saturdaysunday=0;
    restorelastbuttonpressed ();
    manual=0;
    terminal.println();
    terminal.println();
    terminal.println();
    terminal.println("Manual MODE is OFF");
    terminal.println("Auto MODE restored from last status");
    terminal.println("Wait for update (10 seconds as maximum)");
    terminal.println();
    terminal.println();
    terminal.flush();
void resetTerminal()
    terminal.println();
    terminal.println();
    terminal.println();
    terminal.println("New MODE has been selected");
    terminal.println();
    terminal.println();
    terminal.println();
    terminal.flush();
void resetManual()
Blynk.virtualWrite(V1, 0);   //Turn OFF Manual Mode Widget
Blynk.virtualWrite(V2, 0);   //Turn OFF Button Widget Device
BLYNK_WRITE(V2)  // ON-OFF Manual
    if (param.asInt()==1) {  // boton encendido
    terminal.println();
    terminal.println();
    terminal.println();
    terminal.println("Device is ON");
    terminal.println();
    terminal.println();
    terminal.flush();
        if (manual==0){  //está en modo automático
         manual=1;
         mondayfriday=0;
         saturdaysunday=0;
         alldays=0;
         uptoyou=0;
         Blynk.virtualWrite(V1, 1);
         digitalWrite(TestLED, HIGH); // set LED ON
         Blynk.virtualWrite(V2, 1);   //Turn ON Button Widget
         } else {             //está en modo manual
         mondayfriday=0;
         saturdaysunday=0;
         alldays=0;
         uptoyou=0;
    }else {
    terminal.println();
    terminal.println();
    terminal.println();
    terminal.println("Device is OFF");
    terminal.println();
    terminal.println();
    terminal.flush();
        if (manual==0){      //modo automático
         manual=1;
         mondayfriday=0;
         saturdaysunday=0;
         alldays=0;
         uptoyou=0;
         mondayfriday=0;
         saturdaysunday=0;
         alldays=0;
         uptoyou=0;
BLYNK_WRITE(V5)  // Monday-Friday selected
  if (param.asInt()==1 && (V1==1)) {
    timer.setTimeout(50, resetTerminal);
    timer.setTimeout(50, resetManual);
    timer.setTimeout(50, checklastbuttonpressed);
    mondayfriday=1;
    alldays=0;
    uptoyou=0;
    mondayfriday=0;
BLYNK_WRITE(V7)  // Saturday-Sunday selected
    saturdaysunday=1;
    alldays=0;
    uptoyou=0;
    saturdaysunday=0;
BLYNK_WRITE(V9)  // All days selected
    alldays=1;
    mondayfriday=0;
    saturdaysunday=0;
    uptoyou=0;
    alldays=0;
BLYNK_WRITE(V11)  // Up to you selected
    uptoyou=1;
    mondayfriday=0;
    saturdaysunday=0;
    alldays=0;
    uptoyou=0;
BLYNK_WRITE(V4)//Monday-Friday
    sprintf(Date, "%02d/%02d/%04d",  day(), month(), year());
    TimeInputParam t(param);
    terminal.print("M-F Checked schedule at: ");
    terminal.println(Time);
    terminal.flush();
    int dayadjustment = -1;
    if(weekday() == 1){
      dayadjustment =  6; // needed for Sunday, Time library is day 1 and Blynk is day 7
    if(t.isWeekdaySelected(weekday() + dayadjustment)){ //Time library starts week on Sunday, Blynk on Monday
    terminal.println("Monday-Friday ACTIVE today");
    terminal.flush();
    if (t.hasStartTime()) // Process start time
      terminal.println(String("Start: ") + t.getStartHour() + ":" + t.getStartMinute());
      terminal.flush();
    if (t.hasStopTime()) // Process stop time
      terminal.println(String("Stop : ") + t.getStopHour() + ":" + t.getStopMinute());
      terminal.flush();
    // Display timezone details, for information purposes only
    terminal.println(String("Time zone: ") + t.getTZ()); // Timezone is already added to start/stop time
  //  terminal.println(String("Time zone offset: ") + t.getTZ_Offset()); // Get timezone offset (in seconds)
    terminal.flush();
     for (int i = 1; i <= 7; i++) {  // Process weekdays (1. Mon, 2. Tue, 3. Wed, ...)
        if (t.isWeekdaySelected(i)) {
        terminal.println(String("Day ") + i + " is selected");
        terminal.flush();
    nowseconds = ((hour() * 3600) + (minute() * 60) + second());
    startsecondswd = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
    //Serial.println(startsecondswd);  // used for debugging
    if(nowseconds >= startsecondswd){
      terminal.print("Monday-Friday STARTED at");
      terminal.println(String(" ") + t.getStartHour() + ":" + t.getStartMinute());
      terminal.flush();
      if(nowseconds <= startsecondswd + 90){    // 90s on 60s timer ensures 1 trigger command is sent
        // code here to switch the relay ON
    else{
      terminal.println("Monday-Friday Device NOT STARTED today");
      terminal.flush();
    stopsecondswd = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
    //Serial.println(stopsecondswd);  // used for debugging
    if(nowseconds >= stopsecondswd){
      terminal.print("Monday-Friday STOPPED at");
      terminal.println(String(" ") + t.getStopHour() + ":" + t.getStopMinute());
      terminal.flush();
      if(nowseconds <= stopsecondswd + 90){   // 90s on 60s timer ensures 1 trigger command is sent
        // code here to switch the relay OFF
    else{
        digitalWrite(TestLED, HIGH); // set LED ON    test
        terminal.println("Monday-Friday is ON");
        terminal.flush();
  else{
    terminal.println("Monday-Friday INACTIVE today");
    terminal.flush();
    // nothing to do today, check again in 30 SECONDS time
  terminal.println();
 BLYNK_WRITE(V6) //Saturday-Sunday
    terminal.print("S-S Checked schedule at: ");
    terminal.flush();
    if(weekday() == 1){
    terminal.println("Saturday-Sunday ACTIVE today");
    terminal.flush();
      terminal.flush();
      terminal.flush();
    terminal.flush();
        terminal.flush();
      terminal.print("Saturday-Sunday STARTED at");
      terminal.flush();
    else{
      terminal.println("Saturday-Sunday NOT STARTED today");
      terminal.flush();
      terminal.print("Saturday-Sunday STOPPED at");
      terminal.flush();
    else{
        digitalWrite(TestLED, HIGH); // set LED ON  TEST
        terminal.println("Saturday-Sunday is ON");
        terminal.flush();
  else{
    terminal.println("Saturday-Sunday INACTIVE today");
    terminal.flush();
  terminal.println();
BLYNK_WRITE(V8)//All days
  if (alldays==1) {
    terminal.print("All Days Checked schedule at: ");
    terminal.flush();
    if(weekday() == 1){
    terminal.println("ALL DAYS ACTIVE today");
    terminal.flush();
      terminal.flush();
      terminal.flush();
    terminal.flush();
        terminal.flush();
      terminal.print("ALL DAYS STARTED at");
      terminal.flush();
    else{
      terminal.println("All Day Device NOT STARTED today");
      terminal.flush();
      terminal.print("All day STOPPED at");
      terminal.flush();
    else{
        digitalWrite(TestLED, HIGH); // set LED ON  TEST!!!!!
        terminal.println("All day is ON");
        terminal.flush();
  else{
    terminal.println("All day INACTIVE today");
    terminal.flush();
  terminal.println();
BLYNK_WRITE(V10)//Up to you
  if (uptoyou==1) {
    terminal.print("Up to you Checked schedule at: ");
    terminal.flush();
    if(weekday() == 1){
    terminal.println("Up to you ACTIVE today");
    terminal.flush();
      terminal.flush();
      terminal.flush();
    terminal.println("At least ONE day MUST be selected");
    terminal.flush();
        terminal.flush();
      terminal.print("Up to you STARTED at");
      terminal.flush();
    else{
      terminal.println("UP to you Device NOT STARTED today");
      terminal.flush();
      terminal.print("Up to you STOPPED at");
      terminal.flush();
    else{
        terminal.println("Up to you is ON");
        terminal.flush();
  else{
    terminal.println("Up to you INACTIVE today");
    terminal.flush();
  terminal.println();
void reconnectBlynk() {
  if (!Blynk.connected()) {
    if(Blynk.connect()) {
     BLYNK_LOG("Reconnected");
      BLYNK_LOG("Not reconnected");
  if (Blynk.connected()) {
NEW-EDIT: New QR has been made using APP 2.6.0 and Local Server 0.21.6
http://tinyurl.com/ju8pcgp
I have updated the code due to new library v0.4.4 and the New RTC mechanism
There was a little bug at the code for “Up to you” mode… sorry for that…
Kind regards!!
Dear @psoro,
your project is just fine, congratulations!!!
One question: Where did you buy this beautiful enclosure?
Thanks and best Regards,
Mike Kranidis
Great to see the final result! :smiley: A nice little package!
Mind if I steal this?
:wink: love that idea! One less widget required on the dash!
Certainly going in my toolbox.
Nice!
Did you have lags on cloud?
Wonderfull !!! :heart_eyes::heart_eyes::heart_eyes:
if I can suggest you another function it will be very usefull to add a slider to set minutes to stay on. Good for a night lamp :slight_smile:
Thanks everybody for your comments,
@mikekgr,
I did the enclosure using my 3D printer, glad you like it!
@Jamin, @Costas,
It will be a pleasure if you “steal” this idea :relaxed:, this is the way I improve, I don’t remember the times I have done it with before with Costas’ codes!!
@Dmitriy,
I was kidding you because everytime I post a project you ask me if I’m using my own server, :wink:
I use mine since the very beginning so I don’t know about lags on cloud.
@joepesce,
It could be a good idea, thanks for your suggestion but I have no space at the dashboad for more stuff.
I’ll have a look, maybe doing the Terminal a little bit smaller…
Regards,
:grinning::grinning::grinning:
Bad luck, I will never have such a beautiful enclosure… !
Cheers
@mikekgr, send me a PM, I could do perhaps something for you…:slight_smile:
Alas, setProperty is still crashing the app on IoS at latest version of Blynk and library. Nice idea, though :wink:
@drewc228 please elaborate on when you getting a crash on iOS
I think it is the best to use 30000L on blynk server otherwise it floods timer.setInterval(30000L, avtivedoday);
@speed57 5000ms shouldn’t flood the server, even 50ms should be ok.
I tested on 2 different wifi’s and D1 mini’s both of them keep disconnecting from Blynk server.
I set timer in 2 minutes during this time it disconnected 3 times. I don’t know maybe it should work like this.
Pretty sure the 5000ms will not be the reason for the disconnects.
There is problem at least a dozen reasons for ESP’s disconnecting.
Using the exact same sketch as above, the app repeatedly crashes shortly after starting. When I comment out the setProperty statement, it runs as designed. Seems to me there were comments back in November with same issue…not clear if it was ever resolved.
@drewc228 Blynk for Beginners and help with your project
Here is a link to same issue from December: setProperty crashes Blynk app on iOS10
@drewc228 are you going to provide the required details to enable the matter to be resolved?
