My blink app has been working for weeks, updated to IDE 1.6.7 and now no longer reads from analog pin. I get message below when I upload
C:\Users\Computer\Documents\Arduino\libraries\Blynk/BlynkApiArduino.h:100:6: warning: #warning “analogInputToDigitalPin not defined => Named analog pins will not work” [-Wcpp]
#warning "analogInputToDigitalPin not defined => Named analog pins will not work"
I should mention its a Yun and its not just a warning, it doesnt upload unless i go back to 1.6.1. Once I do the sketch uploads and works again with Blynk.
Yea, and please let me know if you can read the values on any pins, digital or analaog. I can send cmds to turn pins on and off, but cant read any values.
Update. I have tried every IDE version from 1.6.1 to 1.6.7 with the new Yun library. I can turn Pins on and off with Blynk but cant read any pins using Blynk, I have confirmed that the input pins are working and reading voltage but nothing is coming through the blink ap I am attempting to rebuild the blynk app I had which was some how removed from the blynk server and now need to start from scratch but seems like either I have had a major brain melt down ( which is possible) or there is a compatibility issue with the Yun. Even a very basic attempt to read a pin with blynk on a widget shows nothing, not even “0”. I have put dozens of hours into this at this point. Can some one simply confirm that the current " BlynkSimpleYun.h" works correctly and allows the reading an displaying of pins. Thank you,
I have tried with Arduino IDE 1.6.11, and everything works as expected.
Value display is showing A0 pin value correctly.
I saw some warnings, and now they are fixed on the latest master branch.
