I have not found (“Blynk community”) the code for the operation of the DS18B20 sensor (waterproof), using “arduino uno” and Ethernet shield W5100.
I want to create a sensor for plants which measures the air temperature and relative humidity, in addition to soil temperature and soil moisture.
At the moment I have the code working for DHT22 (T ° and RH), and the soil moisture sensor, but I can not add the DS18B20 sensor.
If someone could help me appreciate it.
Deputy code that I possess, photography water resistant sensor, and the code of this sensor for operation.
#include "DHT.h"
#include <Ethernet.h>
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
int sensorPin = A0;
int sensorValue = 0;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxx";
Blynk.begin(auth);
timer.setInterval(2000, sendDHT);
void sendDHT()
//Read the Temp and Humidity from DHT
float h = dht.readHumidity();
int hum = (int) h;
int tem = (int) t;
int sensorValue = analogRead(A0);
//Write values to V04 and V05
Blynk.virtualWrite(4, hum);
Blynk.virtualWrite(5, tem);
Blynk.virtualWrite(6, sensorValue);
Serial.println(sensorValue);
Picture of the waterproof sensor (T°)
and the Code of this sensor that i can´t add
#include <OneWire.h>
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
OneWire ds(DS18S20_Pin); // on digital pin 2
void setup(void) {
void loop(void) {
float temperature = getTemp();
Serial.println(temperature);
delay(100); //just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB << 8) | LSB); //using two's compliment
float TemperatureSum = tempRead / 16;
return TemperatureSum;
