Hi
I like to Control Pin 4 of My wemos d1 Mini.
The Pin schould Go high for 1 second when i press the Button in the iOS App.
The normal Button has Not that Funktion.
I dont know know how to start.
Timers… particularly a timeout timer will work
#12 - Timers simplified… perhaps…
Some have a difficult time understanding timers… and since this is a fundamental building block of Blynk… I buried this reference in the middle of this entire topic Well anyhow…
This is a “real world” timer example where i am using two timers to alternately turn ON and OFF an LED… yes, there are many ways to do this, but this example is all about timers.
The first timer will run it’s assigned function 500ms (1/2 second) after boo…
Thank you for your answer.
I found out, that a Button defiend as PUSH Workshop Welle for My Projekt.
Torsten
