Hello everyone,
I am doing this project for my room. I have 3 lights in different positions and I made 3 different devices in order to control these lights from a physical button as well as a through the blynk app. So far I have been able to make this work. The devices talk to each other through bridge and they work great. I only have one small issue. I have one device with 4 physical buttons, these buttons are one per light and the forth is to turn them all on or off at the same time. The issue i am encountering with this is that when I turn them all on or off, if i want to turn one of the lights on or off after that, I need to press of the physical button twise in order for it to turn on and/or off. I would like if anyone is able to help me figure how I am able to just have it work were only one press of the button is needed instead of two.
The way the devices are working are
Module 1 has the 4 physical buttons to control module 2 and 3
Module 2 has a 2 channel relay, which control 2 lights, no physical button on this one.
Module 3 has one relay to control one light as well as one physical button which only control the light attached to this module.
Here is the code for module 1
#include <WiFiUdp.h> //OTA NEEDED
#include <ArduinoOTA.h> //OTA NEEDED
char auth[] = "Module 1 Auth"; //blynk auth token for Main device
char auth2[] = "Module 2 Auth"; //Auth Token for Module #2
char auth3[] = "Module 3 Auth"; //Auth Token for Module #3
char ssid[] = "xxxx"; //Wifi Name
char pass[] = "xxxx"; //Wifi Password // Set password to "" for open networks.
//Bridge Widget on virtual pins
WidgetBridge bridge2(V6); // Module #2
WidgetBridge bridge3(V7); // Module #3
void lightOn(int VPIN);
void lightOff(int VPIN);
boolean LampState1 = 0;
boolean LampState2 = 0;
boolean LampState3 = 0;
boolean LampState4 = 0;
boolean SwitchReset1 = true;
boolean SwitchReset2 = true;
boolean SwitchReset3 = true;
boolean SwitchReset4 = true;
const int Switch1 = D1; // Physical Push Buttons
const int Switch2 = D2;
const int Switch3 = D3;
const int Switch4 = D4;
WidgetLED VLED1(V12); // Two LEDs in the App for relay status from modulo2
WidgetLED VLED2(V13); //
pinMode(Switch1, INPUT_PULLUP);
pinMode(Switch2, INPUT_PULLUP);
pinMode(Switch3, INPUT_PULLUP);
pinMode(Switch4, INPUT_PULLUP);
// OTA CODE NEEDED //
ArduinoOTA.setHostname("UG Room - Door Buttons"); //Device Name
ArduinoOTA.setPassword((const char *)"xxxx"); // Device Password for OTA Upgrades
ArduinoOTA.begin();
// OTA CODE NEEDED ENDS //
timer.setInterval(100, ButtonCheck);
BLYNK_CONNECTED() {
bridge2.setAuthToken(auth2); // Connect via bridge to other devices
bridge3.setAuthToken(auth3);
ArduinoOTA.handle(); //OTA NEEDED
void ButtonCheck() {
boolean SwitchState = (digitalRead(Switch1));
if (!SwitchState && SwitchReset1 == true) {
if (!LampState1) {
bridge2.virtualWrite(V2, HIGH);
LampState1=true;
bridge2.virtualWrite(V2, LOW);
LampState1=false;
SwitchReset1 = false;
delay(50);
else if (SwitchState) {
SwitchState = (digitalRead(Switch2));
if (!SwitchState && SwitchReset2 == true) {
if (!LampState2) {
bridge2.virtualWrite(V3, HIGH);
LampState2=true;
bridge2.virtualWrite(V3, LOW);
LampState2=false;
SwitchReset2 = false;
delay(50);
SwitchState = (digitalRead(Switch3));
if (!SwitchState && SwitchReset3 == true) {
if (!LampState3) {
bridge3.virtualWrite(V3, HIGH);
LampState3=true;
bridge3.virtualWrite(V3, LOW);
LampState3=false;
SwitchReset3 = false;
delay(50);
SwitchState = (digitalRead(Switch4));
if (!SwitchState && SwitchReset4 == true) {
if (!LampState4) {
LampState4=true;
LampState4=false;
SwitchReset4 = false;
delay(50);
void lightOn(int VPIN) {
Blynk.virtualWrite(VPIN, HIGH);
void lightOff(int VPIN) {
Blynk.virtualWrite(VPIN, LOW);
BLYNK_WRITE(V1) { // Status returned from modulo2 (relay1)
int SwitchStatus = param.asInt();
if (SwitchStatus == 2) {
VLED1.on();
else {
VLED1.off();
BLYNK_WRITE(V2) { // Status returned from modulo2 (relay2)
VLED2.on();
else {
VLED2.off();
BLYNK_WRITE(V3) { //If you prefer use a virtual button in V3 for button # 4
else {
Here is Module #2
#define VPIN1 V2
#define VPIN2 V3
char auth[] = "xxxx"; //blynk auth token for modulo2
const int RelayPin1 = D2;
const int RelayPin2 = D3;
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
digitalWrite(RelayPin1, LOW);
digitalWrite(RelayPin2, LOW);
ArduinoOTA.setHostname("UG Room - Door & Bed Light Relays"); //Device Name
ArduinoOTA.begin();
void ToggleRelay1() {
LampState1 = !LampState1;
if (LampState1) {
lightOn(VPIN1);
else lightOff(VPIN1);
void ToggleRelay2() {
LampState2 = !LampState2;
if (LampState2) {
lightOn(VPIN2);
else lightOff(VPIN2);
if (VPIN==VPIN1) {
digitalWrite(RelayPin1, HIGH);
LampState1 = 1;
Blynk.virtualWrite(VPIN1, HIGH);
VLED1.on();
digitalWrite(RelayPin2, HIGH);
LampState2 = 1;
Blynk.virtualWrite(VPIN2, HIGH);
VLED2.on();
if (VPIN==VPIN1) {
LampState1 = 0;
Blynk.virtualWrite(VPIN1, LOW);
VLED1.off();
LampState2 = 0;
Blynk.virtualWrite(VPIN2, LOW);
VLED2.off();
BLYNK_WRITE(VPIN1) {
if (SwitchStatus == 2){
ToggleRelay1();
else if (SwitchStatus){
lightOn(VPIN1);
BLYNK_WRITE(VPIN2) {
ToggleRelay2();
lightOn(VPIN2);
and Module #3
// #define BLYNK_PRINT Serial // Defines the object that is used for printing
// #define BLYNK_DEBUG // Optional, this enables more detailed prints
#define VPIN V3
void lightOn();
void lightOff();
boolean LampState = 0;
boolean SwitchReset = true;
const int TacSwitch = D2;
const int RelayPin = D1;
WidgetLED VLED(V13);
pinMode(RelayPin, OUTPUT);
digitalWrite(RelayPin, HIGH);
pinMode(TacSwitch, INPUT_PULLUP);
ArduinoOTA.setHostname("UG Room - Desk Light"); //Device Name
ArduinoOTA.begin();
boolean SwitchState = (digitalRead(TacSwitch));
if (!SwitchState && SwitchReset == true) {
if (LampState) {
lightOff();
lightOn();
SwitchReset = false;
delay(50);
SwitchReset = true;
void ToggleRelay() {
LampState = !LampState;
if (LampState) {
lightOn();
else lightOff();
void lightOn() {
digitalWrite(RelayPin, LOW);
LampState = 1;
VLED.on();
void lightOff() {
LampState = 0;
VLED.off();
BLYNK_WRITE(VPIN) {
ToggleRelay();
lightOn();
else lightOff();
Thank you everyone!
